hemi orange engine paint #205647
01/27/09 09:46 AM
01/27/09 09:46 AM
NJ
440challenger Offline OP
NJ
I said no to spray bomb and bought some por 15 hemi orange engine paint. has anyone used this before and how were your results/ did you thin it and shoot it and if so with what? Did you brush it on ? Any pics would be great too!! Thanks!
Re: hemi orange engine paint [Re: 440challenger] #205648
01/27/09 10:35 AM
01/27/09 10:35 AM
MO
cdp Offline
cdp  Offline
MO
i used it on my 340 and got good results with spraying it. I'd personally go with Manderine Orange custom mix formula. I think thats what i'm going to use on my 69 440.
I did see the POR flake and peal in a few spots after about 2 years and a little antifreeze discolored it.
Re: hemi orange engine paint [Re: cdp] #205649
01/27/09 12:47 PM
01/27/09 12:47 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
I have done alot of experimenting with paints and to be honest with you, my best results have been with a spray can.
If your looking for a very shinny, glossy looking engine then go for the gun but if your looking for a realistic looking engine, I find that the old rattle can works for me.
Just my
PS.....I believe the closes looking paint on the market is the Duplicolor Chrysler Orange.....not the hemi orange but the Chrysler Orange.
OK, let the begin
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: hemi orange engine paint [Re: Troy] #205650
01/27/09 02:33 PM
01/27/09 02:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
u-tech 3.8 HSP
U-TECH 3.8 Polyurethane System - High Solids System
U-TECH 3.8 System High Solids low VOC 2K Polyurethane single stage topcoat designed
to produces a very flexible impact resistant film. U-TECH 3.8 Polyurethane, incredible hiding
power that meets the productivity needs of the Fleet market as well as the light commercial
to heavy commercial markets.
More importantly the intermix tinting system allows for color formulas available for both fleet
and automotive saving time and reducing cost.
Product Features:
- Hiding Power
- Very Flexible
- High Gloss
- Easy-To-Spray
- Fast Cure
- Long Term Durability
DUPONT CODE : 5067U
Find a sikkens dealer and they can get it.
Re: hemi orange engine paint [Re: Troy] #205651
01/27/09 04:20 PM
01/27/09 04:20 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Just my
OK, let the begin
Troy,
I agree as well, we have all seen the engines
that look like the paint is 1/8 inch thick and
and as shinny as a new John Deere tractor.
The low luster spary bomb looks more correct.
logan426
Re: hemi orange engine paint [Re: MLR426] #205652
01/28/09 09:15 AM
01/28/09 09:15 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
The POR15 is very shiny abd the color is on the pale side.
Re: hemi orange engine paint [Re: AdamR] #205653
01/28/09 09:47 PM
01/28/09 09:47 PM
BRawls Offline
super gas
BRawls  Offline
super gas
I just did a 440 brushing and it came out OK. the POR does not cover well and I had to go over it 3 times to make it look good. I'll spray next time.
Re: hemi orange engine paint [Re: BRawls] #205654
01/28/09 09:55 PM
01/28/09 09:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm with Troy, POR15 (as well as most other brush on mixes) result in a finish that is too thick, the wrong color, and way too glossy in appearance. The factory shot single stage enamel on the bare metal engines, no primer, nothing, just a fast but fairly heavy coat of color. It was pretty slow drying so it thinned and flattened as it dried.
Modern rattle cans offer a similar look if applied correctly. Although I haven't seen anything from a rattle can that's 100% exact to OEM, but the stuff you can buy from Mopar Perfomance these days (the new mix) is pretty dan accurate! FWIW I don't think the Duplicolor mix is nearly as close.
Re: hemi orange engine paint [Re: RobX4406] #205655
01/28/09 10:59 PM
01/28/09 10:59 PM
SOUTHERN, MN
MOPARRESTORER Offline
SOUTHERN, MN
u-tech 3.8 HSP
I agree this has been a very good product for us. We have been using it for years with no problems.
Re: hemi orange engine paint [Re: MOPARRESTORER] #205656
01/29/09 08:43 AM
01/29/09 08:43 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
U-Tech, is Sikkens owned.
Re: hemi orange engine paint [Re: ScottSmith_Harms] #205657
01/31/09 01:51 PM
01/31/09 01:51 PM
Fairfield, Ohio
holtzdog55 Offline
holtzdog55  Offline
Fairfield, Ohio
Pretty sure my brother used this when he painted my engine....looks pretty good to me anyway....
http://store.summitracing.com/partdetail...mp;autoview=sku
Finally Done....BEERS!!!
Re: hemi orange engine paint [Re: holtzdog55] #205658
01/31/09 01:52 PM
01/31/09 01:52 PM
Fairfield, Ohio
holtzdog55 Offline
holtzdog55  Offline
Fairfield, Ohio
pic of paint....
Re: hemi orange engine paint [Re: holtzdog55] #205659
01/31/09 08:31 PM
01/31/09 08:31 PM
MO
cdp Offline
cdp  Offline
MO
Couldn't you have the U-Tech deglossed about 10-15% and get a more correct appearance?
I've heard the U-Tech has exceptional color hold out and is very resistent to gas spills/antifreeze, etc. Everything a good poly-paint should do.
Re: hemi orange engine paint [Re: cdp] #205660
01/31/09 09:13 PM
01/31/09 09:13 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
What is the Ditzler # for the tangerine orange that I saw her previously? Should be a DAR enamel paint with certain % flattening agent.
Re: hemi orange engine paint [Re: sawdust] #205661
02/01/09 12:42 AM
02/01/09 12:42 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Seems to a bit of confusion on this thread. DURABLE paint is not what I'm commenting on, CORRECT shade of paint is what I'm commenting on. Two different subjects. As far as correctness, as I said above, it's pretty hard to beat the current Mopar rattle can stuff, it's pretty durable as well if you prep the metal first and apply it properly.
That's Dave Walden's (ECS) custom blend that he came up with when he matched some of the original engine paint on his 1970 440
Re: hemi orange engine paint [Re: ScottSmith_Harms] #205662
02/01/09 01:01 AM
02/01/09 01:01 AM
RobX4406 Offline
RobX4406  Offline
My LD340 intake looks like junk after being painted with mopar paint from a rattle can. It was spotlessly clean, painted and got some fuel on it and most of the paint lifted. Quality stuff.
Re: hemi orange engine paint [Re: RobX4406] #205663
02/01/09 01:27 AM
02/01/09 01:27 AM
So Dak
GOLDENCOMMANDO Offline
So Dak
Heres the previous post.I'm still looking for the DAR code for the max wedge.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: hemi orange engine paint [Re: GOLDENCOMMANDO] #205664
02/01/09 02:16 PM
02/01/09 02:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No reason for the ........As I already said, I was not speaking on quality of adhesion, chemical resistance, or any other durability issues. The color is right, that's it.
*BTW, FWIW I've used it allot and had no issues with it lifting as you described.
Re: hemi orange engine paint [Re: ScottSmith_Harms] #205665
02/01/09 04:49 PM
02/01/09 04:49 PM
RobX4406 Offline
RobX4406  Offline
Ever seen two factory painted engines in SH orange be different shades? What's correct?
Just like B5 cars of the same year. Two can be painted B5 from the factory and the shades aren't exactly the same... so which is correct.
Not everyone is concerned with OE correct shades, of course you have to know which is actually correct because there was more than one shade variation. Spray gun stuff is much better, more durable and you could even flat it to get rid of the bothersome gloss.
The mp rattle can stuff, IMO, is garbage at best.
Re: hemi orange engine paint [Re: RobX4406] #205666
02/01/09 11:28 PM
02/01/09 11:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes it varied, but not a ton, we are talking slight variations. There are plenty of durable paints out there, no doubt much better than rattle can or original paint on engines in terms of quality. However, MOST of todays aftermarket blends are not even close to matching any range of factory color shades, and custom flattening agents aside, are usually a mile off on the amount of gloss as well (a couple reasons that likely lead Dave Walden to match his own blend to original engine paint). So what it boils down to is that it really depends on what your priorities are.
