Coil getting too hot causing a rough idle? #2052155
04/11/16 09:10 PM
04/11/16 09:10 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
Do you guys suppose its possible for an MSD Blaster 2 coil to get too hot and cause the idle to get bad enough to where it feels like there is a cylinder or 2 down? Its mounted on a Performer RPM right in front of the carb, the motor can run up to 210 or so. The idle is great cold and very responsive but when its up to temp and coming to stop at a light it idles down really low and rough and will surge like its trying to pick up the dead cylinder.
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2052171
04/11/16 09:30 PM
04/11/16 09:30 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
no, coils are generally good or bad not in between
Re: Coil getting too hot causing a rough idle? [Re: mcat4321] #2052410
04/12/16 12:26 AM
04/12/16 12:26 AM
engage the carb power circuit & see what happens. sub in another coil & see what happens.
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2052420
04/12/16 12:33 AM
04/12/16 12:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Coils can and do break down... but it can be a
LEAN carb... try a coil.. it made a day and night
difference on my junk
EDIT
I know I wasnt lean.. I was fouling out plugs
wave
Re: Coil getting too hot causing a rough idle? [Re: MR_P_BODY] #2052521
04/12/16 02:11 AM
04/12/16 02:11 AM
Phoenix, AZ
Phoenix, AZ
OK, I'll try a couple of things mentioned here. I have a stock replacement coil I can sub in and see what happens and then try some more carb tuning.
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2053127
04/12/16 10:22 PM
04/12/16 10:22 PM
ont, canada
K
kenny b Offline
kenny b  Offline
K
ont, canada
Back some years ago when I was a chrysler tech there was a service bulletin about coils. 76 and 77 cordobas and some other rear wheel drive cars would cut out going around corners. Turned out to be the coil shorting out from lack of oil, Loose cores inside the coil and or the coil heating up and cutting out. We replaced the coil and no problem afterwards.
Kenny B
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2055365
04/16/16 02:42 AM
04/16/16 02:42 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
All coils are not the same. There are high and low resistance coils. Some types of ignitions need the resistance, some don't. Using a ballast adds resistance...
This could explain an overly hot coil.
Good Luck
Re: Coil getting too hot causing a rough idle? [Re: TheBlackCar] #2055475
04/16/16 12:27 PM
04/16/16 12:27 PM
Phoenix, AZ
Phoenix, AZ
I am concerned about heat radiating from the engine causing the coil overheat. I also plan on moving to the inner fender and seeing if that changes anything.
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2055486
04/16/16 12:36 PM
04/16/16 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your using a coil that calls for a resister
and your not using a resister and running 12v
to it.. it will get HOT.. engine heat shouldnt
be a issue.. plenty of coils were mounted on the
intake.. now days they have 8 coils mounted on
the valve covers without issue... even on a HOT
heat soak the under hood temps get up to 300*..
and that was on a super hot day on top of black top
(117* that day in Death Valley)
wave
Re: Coil getting too hot causing a rough idle? [Re: MR_P_BODY] #2055501
04/16/16 01:03 PM
04/16/16 01:03 PM
Phoenix, AZ
Phoenix, AZ
Using a ballast resistor, Firecore dist, MSD Blaster 2 coil.
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2055540
04/16/16 02:07 PM
04/16/16 02:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Since I moved my coil,ford starter relay and ign. box under the pass. side of the dash, everything last longer and the MSD 6200 box is well over 10 years old..........
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2055671
04/16/16 06:04 PM
04/16/16 06:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does that coil want a resistor ?
does your fuel have 10% ethanol ???
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2055674
04/16/16 06:18 PM
04/16/16 06:18 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Sounds like the fuel is boiling.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Coil getting too hot causing a rough idle? [Re: Belvedere1] #2056289
04/17/16 06:28 PM
04/17/16 06:28 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I would upgrade to an E-coil and a GM HEI module.
The E-coil is much more efficient, can run on 12v and still doesn't get hot.
Re: Coil getting too hot causing a rough idle? [Re: JohnRR] #2056429
04/17/16 10:45 PM
04/17/16 10:45 PM
Phoenix, AZ
Phoenix, AZ
It is used with a resistor. Yes, the gas out here is ethanol 91 octane. It very well could be boiling. I have a thick base gasket to help with that issue but it may very well be getting close to boiling. I just keep putting off going to an electric pump.
