Door End Glass Seal? #2056095
04/17/16 01:18 PM
04/17/16 01:18 PM
68gtx Offline OP
68gtx  Offline OP
Working on a 68 GTX. My question is where the door end seal and the door weatherstrip meet do you trim the seal to meet the door end seal? And do you use trim adhesive to mate the 2. Any pictures of this area would help where the door end seal and the door weatherstrip meet. Thanks Larry J IMG_0695.jpg
Re: Door End Glass Seal? [Re: 68gtx] #2056322
04/17/16 07:22 PM
04/17/16 07:22 PM
68gtx Offline OP
68gtx  Offline OP
Anyone???
Re: Door End Glass Seal? [Re: 68gtx] #2056325
04/17/16 07:27 PM
04/17/16 07:27 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
not real clear what you are referring to. is it this little guy?
https://www.yearone.com/SearchResults/Chrysler-B-Body/fr3345
Re: Door End Glass Seal? [Re: 68gtx] #2056360
04/17/16 08:30 PM
04/17/16 08:30 PM
68gtx Offline OP
68gtx  Offline OP
No its the molded seal thats held in by 3 screws at the very top of the door and then the weatherstrip continues around the door. I will try to post a picture. Thanks Larry j
Re: Door End Glass Seal? [Re: 68gtx] #2056374
04/17/16 08:55 PM
04/17/16 08:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Re: Door End Glass Seal? [Re: 68gtx] #2056376
04/17/16 08:59 PM
04/17/16 08:59 PM
68gtx Offline OP
68gtx  Offline OP
Yep thats the one. So the installation of that end seal is just bolt it on but does the weatherstrip get cut to fit up against the end seal? A picture would really help. Not sure what happen to my attachment.?? Thanks Larry j
Re: Door End Glass Seal? [Re: 68gtx] #2056382
04/17/16 09:10 PM
04/17/16 09:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
2 minutes...
Re: Door End Glass Seal? [Re: 68gtx] #2056390
04/17/16 09:30 PM
04/17/16 09:30 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
from my 69 RR
edit - i should add that my weatherstripping is original. only had it off for painting. pretty sure i got it back on right all those years ago biggrin
Re: Door End Glass Seal? [Re: 68gtx] #2056406
04/17/16 09:58 PM
04/17/16 09:58 PM
68gtx Offline OP
68gtx  Offline OP
Thanks!!!!!!!!!!!
