5.7 - 6.4 MDS #2055197
04/15/16 09:56 PM
04/15/16 09:56 PM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
I have been looking at newer trucks ( 2014-2016 ) and seeing the MDS after the enging size . What does the MDS stand for & what does it do ? Would it be wise to just buy a truck without this ? I tow a 26' enclosed car hauler & want to stay with gas . Gary
Re: 5.7 - 6.4 MDS [Re: Gabby63] #2055209
04/15/16 10:19 PM
04/15/16 10:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Multi displacement system. It shuts off 4 cylinders at cruising speed to save fuel.
Re: 5.7 - 6.4 MDS [Re: Gabby63] #2057864
04/19/16 08:13 PM
04/19/16 08:13 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
2009-2014 5.7 V8s have a recall out just recently where an all plastic shoe in the timing chain tensioner mechanism cracks in two and is causing the chain to break after many hours in MDS mode. Severe engine damage occurs. Hemi V8 s in front of manual transmissions are not having the plastic shoe crack, at least yet.
Re: 5.7 - 6.4 MDS [Re: 360view] #2058144
04/20/16 02:11 AM
04/20/16 02:11 AM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
So will all engines have this MDS ? Can it be turned off ( switch ) Thanks Gary
Re: 5.7 - 6.4 MDS [Re: Gabby63] #2058202
04/20/16 08:39 AM
04/20/16 08:39 AM
USA
3
360view Offline
360view  Offline
3
USA
It varies by year and model.
Aftermarket chips are sold for some year models.
Some models have transmission settings that lock out tow haul.
It will take dealerships so long to fix the plastic shoe on the timing chain on this many affected engines that i would not be surprised if FCA issues a TSB that locks out MSD until the repair can be started.
My memory is fuzzy but i believe that if you wire in a resistor into the Engine Coolant Temperature Sensor thermistor to fool the PCM computer into thinking that temperature is less than 183 degrees, MDS will not engage because "warm up" has not completed. This will set a check engine light.
Re: 5.7 - 6.4 MDS [Re: 360view] #2058796
04/21/16 02:11 AM
04/21/16 02:11 AM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
Hey , thanks for the info , hopefully they will get a handle on this issue . I do hope it is not activated while in tow mode . Gary
Re: 5.7 - 6.4 MDS [Re: 360view] #2059215
04/21/16 07:06 PM
04/21/16 07:06 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Or you could simply unplug the harness that sends the signal to the solenoids to switch into 4cyl mode. It runs into the lifter valley on the driver's side rear of the engine, I believe it is a 6 wire plug.
Re: 5.7 - 6.4 MDS [Re: Gabby63] #2059274
04/21/16 09:22 PM
04/21/16 09:22 PM
WV
WV Runner Offline
WV Runner  Offline
WV
Can buy a diablo sport tuner and shut it off also.
