a number 12 tag #2055059
04/15/16 06:13 PM
04/15/16 06:13 PM
Aubrey, Texas
O
oldtimer5151 Offline OP
O
Aubrey, Texas
I have a number 12 tag welded to my k frame. What does it mean?
Re: a number 12 tag [Re: oldtimer5151] #2055063
04/15/16 06:18 PM
04/15/16 06:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
12 - Last two digits of the part number.
Re: a number 12 tag [Re: Alaskan_TA] #2055073
04/15/16 06:35 PM
04/15/16 06:35 PM
Aubrey, Texas
O
O
Aubrey, Texas
No this is a special tag with a spot weld to hold it? It is on the front of the k-frame>
Re: a number 12 tag [Re: oldtimer5151] #2055075
04/15/16 06:38 PM
04/15/16 06:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yep, I know what it is. Common though, not 'special'. wink
Re: a number 12 tag [Re: Alaskan_TA] #2055092
04/15/16 06:56 PM
04/15/16 06:56 PM
Aubrey, Texas
O
O
Aubrey, Texas
I havent seen it on many k-frames. What does it mean?
Re: a number 12 tag [Re: oldtimer5151] #2055109
04/15/16 07:11 PM
04/15/16 07:11 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The first guy that responded answered your question.
Ron
Re: a number 12 tag [Re: RJS] #2055137
04/15/16 08:17 PM
04/15/16 08:17 PM
Aubrey, Texas
O
O
Aubrey, Texas
It is not the last numbers of the vin number.
Re: a number 12 tag [Re: oldtimer5151] #2055138
04/15/16 08:18 PM
04/15/16 08:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
PART number.
Not VIN number.
Re: a number 12 tag [Re: oldtimer5151] #2055141
04/15/16 08:28 PM
04/15/16 08:28 PM
Aubrey, Texas
O
O
Aubrey, Texas
Other 383 cudas like mine did not have the tag.
Re: a number 12 tag [Re: oldtimer5151] #2055142
04/15/16 08:31 PM
04/15/16 08:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Is it in a 1970 E-body? If so, the same K-frame was used in 318, 340 & 383 cars until the 52 K-frame replaced it.
If it is original to your car, you can check the broadcast sheet (if you have one for it) & the number should match.
Re: a number 12 tag [Re: oldtimer5151] #2055143
04/15/16 08:32 PM
04/15/16 08:32 PM
Aubrey, Texas
O
O
Aubrey, Texas
I saw one on a hemi cuda in Vegas in 2014 and he thought that there were so many built with certain options. mine was the 26,001 built. His had a 54 tag on his.
Re: a number 12 tag [Re: oldtimer5151] #2055146
04/15/16 08:36 PM
04/15/16 08:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
He was wrong.
As far as xxxth built thing goes, there is no way to know the order that all the 383 Cudas were built in.
Re: a number 12 tag [Re: oldtimer5151] #2055147
04/15/16 08:36 PM
04/15/16 08:36 PM
Aubrey, Texas
O
O
Aubrey, Texas
yea It could have been a 52. So the 12 is the k-frame part number?
Re: a number 12 tag [Re: oldtimer5151] #2055151
04/15/16 08:38 PM
04/15/16 08:38 PM
Aubrey, Texas
O
O
Aubrey, Texas
I have the tag on the fender and caint find the #12,
Re: a number 12 tag [Re: oldtimer5151] #2055155
04/15/16 08:40 PM
04/15/16 08:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It is not listed there, so I am not surprised.
Re: a number 12 tag [Re: oldtimer5151] #2055162
04/15/16 08:42 PM
04/15/16 08:42 PM
Aubrey, Texas
O
O
Aubrey, Texas
thank you 4 the help.
Re: a number 12 tag [Re: oldtimer5151] #2055163
04/15/16 08:46 PM
04/15/16 08:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If you have a broadcast sheet for it, look for the '12' on line 4 under the word 'FRAME'.
Re: a number 12 tag [Re: oldtimer5151] #2057209
04/18/16 10:36 PM
04/18/16 10:36 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
12 is the last two numbers in the Chrysler part number.
