Dakota brakes #2054210
04/14/16 12:21 PM
04/14/16 12:21 PM
pennsylvania
poboyengineering Offline OP
pennsylvania
I did some parts store research and it seems the 4cyl trucks came with 9" rear drums. Is this true, and does anyone have a set of backing plates for this?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Dakota brakes [Re: poboyengineering] #2054213
04/14/16 12:28 PM
04/14/16 12:28 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Had a 2000 ext cab 4.7 4x4 with 9" rears. Should be easy to find I thinks.
Re: Dakota brakes [Re: poboyengineering] #2054718
04/15/16 01:21 AM
04/15/16 01:21 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Rear brake choices of the early Dakota were either 9" or 10". Should be lots of 9" backing plates around. Now if someone wants to part with only the backing plates would be another question. I have a Dakota rear axle here from a parts truck, but the axle is still good, not sure I would want to go through the work of pulling off the backing plates, and on top of that, I'd have to measure if they were 9" or 10" brakes.
On the other hand, if the rear axle from my 4x4 craps out, I'd pull those 9" backing plates off and send them to you. Gene
