Re: 61-93 Dodge truck splash shield questions
[Re: 71TA]
#2053958
04/13/16 11:28 PM
04/13/16 11:28 PM
Posts: 43,642 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
If you come over to the Chicago area anytime soon I have 64, 66, 67 68, 69, 78, 92, and 93 trucks laying around that you can check out... ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: 71TA]
#2054204
04/14/16 12:08 PM
04/14/16 12:08 PM
Posts: 1,449 Orange Park FL.
LilRed7879
Orange Park FL.
I just finished making what I think are all the radiator and frame rail splash shields for 72-79 dodge trucks. There are 4 different versions of just the splash shields on the top of the radiator. 2 different below. And 3 different frame rail splash shields.
So I have a few questions.
1) there are flat metal clips, not the wire push in clips, that hold the large flat splash shields to the frame rails on the 72-79? trucks. I could use a good picture of one of those and approx dimensions. I'm looking to have those made from stainless like the stainless wire form push clips I had made. I'd actual like to buy one or two or trade.
2) I'd like to ID all the different splash shields as to what years/models they are from and any differences from the all the ones I have. I'll add pictures in a bit.
3) lastly I'd like to buy any 61-71 or 82-93 truck splash shields. I'd also replace with new ones.
Thanks Jim Fillmore
Jim - I will try and get you some info on the flat clips Auveco made them until about 3 years ago and I believe I kept a few in my personal items. I believe Auveco still makes a similar clip without the rubber on the end also.
[Re: poorboy]
#2056525
04/18/16 12:49 AM
04/18/16 12:49 AM
Posts: 12,439 Warren, MI
71TA
Warren, MI
Would you be interested in the inner fenders to frame flaps off a 91 Dakota 2x4? I have a fairly decent set here I could offer up. Gene Can you take a picture of the Dakota splash shields?
[Re: Rhinodart]
#2056808
04/18/16 03:14 PM
04/18/16 03:14 PM
71TA
Warren, MI
That is a 70-71 grille on that PW, though probably the same for 69. Yep. While I was looking at stuff I was interested in the other guys were comparing the differences and similarities between 68-71 trucks. Wish i had time to get over to Chicago. Isn't there a Mopar show coming up soon?
[Re: 71TA]
#2058820
04/21/16 03:10 AM
04/21/16 03:10 AM
Posts: 10,654 Freeport IL USA
poorboy
Freeport IL USA
Would you be interested in the inner fenders to frame flaps off a 91 Dakota 2x4? I have a fairly decent set here I could offer up. Gene Can you take a picture of the Dakota splash shields? I'll dig em out and get a couple of pictures. It will be sometime next week, I got hammered with work this week. Gene
[Re: 71TA]
#2058955
04/21/16 01:02 PM
04/21/16 01:02 PM
LilRed7879
Orange Park FL.
So below are 4 versions of radiator splash shields for 72-79 trucks.
The top smallest ones came off a 79 Lil Red. I've seen these without the oval holes (for the overflow tube) either not cut at all or perf cut so they can be popped out if needed.
The 2nd pic is another version of the small ones.
the 3rd and fourth picture I'm assuming is for an A/C truck or big block truck to enhance airflow. Tht is JUST a guess. Any help why there is a difference between using the small radiator shields and these large ones would be appreciated. ALSO note the only difference between the 3rd and 4th picture are the widths of the lower "legs". On the one in the 4th picture the "leg" has 2 clip holes.
Any help identifying years/models/reasons for use would again be appreciated. So best I can tell from the ones we have always sold - 1st one - is for a 79 with a coolant overflow tank 2nd one - is for a 78 with a coolant overflow tank 3rd and 4th - we only have one version of but it has been used on 72-80 withOUT a coolant tank. I have no idea whether it was engine size or AC that caused trucks to have coolant tanks or not but there seems to be a mix/variety of configurations out there. http://www.dodgeconnection.com/page/page/2901770.htm
