Re: Holley Problems
[Re: elmor353]
#2052466
04/12/16 01:08 AM
04/12/16 01:08 AM
RapidRobert
Holley newbie but what I'd do is take off the square pump cover with the 4 bolts & start with a visual. Not sure what Holleys use for a check valve like the ball and or tapered rod that carters use. look for anything stuck/missing/that dont look right
Re: Holley Problems
[Re: elmor353]
#2052501
04/12/16 01:47 AM
04/12/16 01:47 AM
Posts: 6,445 Missouri
68KillerBee
Missouri
Maybe mess with the different cams that they come with. Contorts amount and how long fuel sprays. If I'm off, somebody tell me and I'll delete this misinformation Edit: power valve idea deleted
Re: Holley Problems
[Re: elmor353]
#2052834
04/12/16 03:25 PM
04/12/16 03:25 PM
Posts: 561 Oakland, CA
68Bullet
Oakland, CA
I just went through this on my Demon carb. There is a small umbrella looking rubber piece under your larger rubber diaphragm. The umbrella has a barbed extension. Be sure that the barb of the extension goes fully through the mounting hole. I had not fully engaged the barb, and I was having the same problem as you. The barb should go through the mounting hole and the umbrella should seat flat against the bottom of the housing. The umbrella acts like a check valve and so if it doesn’t seat correctly it will allow the accelerator pump shot pressure back into your carburetor bowl.
"Broke is temporary, cheap lasts forever"
Re: Holley Problems
[Re: elmor353]
#2053160
04/12/16 11:03 PM
04/12/16 11:03 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The inlet check ball under the small metal strap needs to be free and move a little. It needs to drop down a tad to pull fuel in past it and then it needs to move back up a tad and seat so no fuel pushes out past it and all the fuel goes out the discharge passage. Also under the squiter will be a check ball or a check ball and a weight or a type of pointed weight to seal. It has to lift up to let fuel squirt past it when you push the pedal down and then it has to drop back down and seat so the pump pulls no air in past it when the pump refills. I would make sure both are free and seat good. Ron
