Re: Removing a Steering Column
[Re: 440charger70]
#205192
01/26/09 08:39 PM
01/26/09 08:39 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
never took one out of a B body...
but there is a roll pin on the end of the shaft at the power steering sector...that needs to be driven out..
3 bolts on firewall removed from inside...
3 or 4 bolt that hold steering column up into lower dash...
it might have a plastic cover under the column that will be needed to be removed before getting to the under dash bolts..
also..good to have someone help and hold column as you remove it from the power steering sector..
you dont want the column to collaspe...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#205194
01/27/09 01:00 AM
01/27/09 01:00 AM
RapidRobert
very important to have a helper hold(& pull back) the col inside the car when you undo the coupler at the steering box.
