Re: I hate my T/A shifter. What are my options?
[Re: rt66jim]
#2051539
04/11/16 01:01 AM
04/11/16 01:01 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
I'm happy with my B&M Proratchet . Easy adjust .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: rt66jim]
#2051546
04/11/16 01:08 AM
04/11/16 01:08 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I'll second the B&M pro ratchet. I had one in my dart and it worked great. Absolutely no missed shifts. Never used a T/A shifter. They just look like they would be a pain in the a$$ to operate.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: rt66jim]
#2051558
04/11/16 01:19 AM
04/11/16 01:19 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
Actually the T/A shifter was easy to operate... but it's a gate shifter that relies on the detents on the rooster comb of the valve body for positive stops on the reverse pattern gate. This same gate was also famous for the dreaded 1-3 ahift. I found that if you "hit" the shifter from 1-2, it would line up for the 2-3. If you "pulled" the shifter, often it would cruise right past the stop and go 1-3. it's just that when we went to the W8 mill, it launched hard enough to make the 1-2 shift on it's own. I ended up buying a different gate and modified the "rooster comb" for a tighter fit, but the PPP deal came up so down the road it went. The PPP is a ratchet style shifter and is imho the smoothest, quickest, most positive piece we've had in the car (shifter #3). Right now I'm using it manually as I'm running the Heritage series, but when It's back to Pro ET class, in goes the air and timer and it works great.
[Re: rt66jim]
#2051605
04/11/16 02:27 AM
04/11/16 02:27 AM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
Went racing again yesterday. Had the same problem. Made 5 runs and on 2 of them went 1 to 3rd. I ready to get rid of this thing unless there is a simple cheap solution. Anyone else had this problem and solved it? Jim Not sure which gate you have but when mine did this it was always my fault. I pulled the handle back and towards me which would bring it into 3rd. Simple fix was to simply push right as I pulled . I never missed a shift again. Been using mine since the mid 80's.
Ok
[Re: J_BODY]
#2051609
04/11/16 02:34 AM
04/11/16 02:34 AM
cudatom
Massillon, Ohio
The gate in my hand is the "recommended" reverse pattern T/A piece.... right below the raised stop sticking up near my thumb was N, you'd then pull it one step back to 1. Prob was that when we launched, back it would come. I swapped to my clean N t-brake and installed the other gate that's shown on the shifter. It's actually the forward pattern gate, but worked "ok" for what I needed to do. There's better tools in the shed out there now. This was "high tech" in like the early 80's. ....and it was an interesting conversation with Paul when I was explaining what was going on. Got even better when "clean N" trans brake came into the conversation. J_Body the gate in your shifter is the one that came w/my shifter back in the 80's. It was listed as a reverse pattern shifter. That's also the same gate that came in my brothers shifter in the mid 2000's. I've never seen the gate you have on the right.
Ok
[Re: cudatom]
#2051619
04/11/16 03:26 AM
04/11/16 03:26 AM
J_BODY
aZLiViN
back in the day "this" was the shifter gate they (T Action) said I needed for my reverse pattern T brake highlighted in yellow in this summit ad: http://www.summitracing.com/parts/tac-70076b/overview/the two on the left in the white box could use either, but was also recommended for clean N use and included a decal that make the "N" position "1".... which still left a straight shot back to "2" which still means I would still had to stiffen the valve body to prevent "automatic" shifting. Take the cable off a T/A shifter and you'll see how they just pretty much "flop" from front to back. the other gate "worked" but was awkward imho
[Re: J_BODY]
#2051699
04/11/16 10:25 AM
04/11/16 10:25 AM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
If you run the RVB, use the FVB gate.....slap it straight on the 1-2 and slightly over on the 2-3 and there's no way to miss. I don't like the RVB gate at all.
To me the 1-2 is the critical shift and using the FVB pattern on a RVB the 2-3 is over (slightly) and back so you can hit the 1-2 as hard as you want. I don't see how you can miss 1-2 or inadvertently go 1-3 using it. I was already racing 4 speeds for 20 yrs before I ever raced with an automatic though.
[Re: rt66jim]
#2051708
04/11/16 10:36 AM
04/11/16 10:36 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I hated my Cheetah shifter for the same reason, I would pull from 1st to 3rd too, I love my B&M pro ratchet.
I tried every TA gate made, no diff... I still lost rounds
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: rt66jim]
#2051792
04/11/16 01:12 PM
04/11/16 01:12 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
Quarter stick. Cheap and bulletproof.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2051798
04/11/16 01:18 PM
04/11/16 01:18 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
[Re: rt66jim]
#2051802
04/11/16 01:29 PM
04/11/16 01:29 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I love my TA shifter, and if one day it starts to kick out of 1st on its own I will be happy that my car is leaving that hard lol. I have had zero issues missing 2nd with mine.
If I were to change shifters I would go quarter stick.
68 Barracuda Formula S 340
[Re: rt66jim]
#2051812
04/11/16 01:39 PM
04/11/16 01:39 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I have personally like the Cheetah shifter, never had any issues with one. I like the looks of the PPP shifter but their customer service sucks!
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: rt66jim]
#2051848
04/11/16 02:18 PM
04/11/16 02:18 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
I have never had an issue with my T/A shifter either.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
