Re: Monster Mopar/Mustang? [Re: POZEST] #2051617
04/11/16 03:13 AM
04/11/16 03:13 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Wouldn't mind taking the Buick to run there in Outlaw Limited Street, but their weight is too heavy. Have to put 500 pounds in car
Re: Monster Mopar/Mustang? [Re: POZEST] #2051677
04/11/16 09:03 AM
04/11/16 09:03 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I didn't know chads car weighed 2600lbs
Re: Monster Mopar/Mustang? [Re: Gary Robbins] #2051994
04/11/16 05:52 PM
04/11/16 05:52 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Originally Posted By Gary Robbins
Sounds like fun as I enjoy putting MUDSTAINS back in the box !!
Thanks Gary!!!
You are the best
Re: Monster Mopar/Mustang? [Re: joshking440] #2052006
04/11/16 06:06 PM
04/11/16 06:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That's in "Outlaw trim". We have to be 2750-2800 for Drag Radial or Limited Drag Radial
Re: Monster Mopar/Mustang? [Re: Monte_Smith] #2052014
04/11/16 06:26 PM
04/11/16 06:26 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Wouldn't mind see that at all! There's a GN here that street driven and runs high 8's.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Monster Mopar/Mustang? [Re: POZEST] #2052177
04/11/16 09:34 PM
04/11/16 09:34 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I think you can weigh 3100 and race with these guys
Re: Monster Mopar/Mustang? [Re: POZEST] #2052258
04/11/16 10:40 PM
04/11/16 10:40 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
2016 OLS
Must have mufflers (except turbo entries)
Must have working headlights and taillights
Lexan allowed (windows do not have to function)
After market bolt on front clip allowed
Tube Chassis limited to stock wheelbase +/- 1”
Tube Chassis required to carry 50% on front tires
Pro chargers are limited to a F3-139 series
Alcohol permitted
**Above 101 Turbo and F-3 Supercharged cars limited to 31X10.5W tire or DOT Radial**
**Any roots blower 8-71 and smaller can run any tire**
**Any roots over 8-71 limited to 31x10.5W tire**
**Any F-2 Procharger or 101 and smaller turbo can run a 33W tire**
Any HEMI heads on 5" or larger bore space limited to 31W tire
ANY ENGINE(n/a or nos)OVER A 5" BORE SPACE LIMITED TO 31W
2250lbs. small block N/A
2550lbs. small block NOS (2 stages) add 50lbs for 3rd stage
3000lbs. small block blowers and single turbo
3200lbs small block twin turbo (true 10.5 or DOT Radial/no wheelie bars)
2400lbs. BB N/A conventional heads
2500lbs. BB N/A Chrysler with non conv heads
2550lbs. BB N/A under 5"bs non conventional heads
2700lbs. BB N/A 5" bs
2800lbs. BB N/A over 5"bs
2900lbs. BB NOS with conventional heads(single stage)
2950lbs. BB NOS with conventional heads(two stage)
3100lbs. BB NOS non-conventional heads-single stage
3200lbs. BB NOS UNDER 5"BS non-conv two-stage(big tires)
3200lbs. BB NOS 5" and over non-conv two-stage run on 31W tire
3100lbs. BB blowers and single turbo
3300lbs BB twin turbo (true 10.5 or DOT Radial/no wheelie bars)
Add 50lbs for ANY billet heads
Add 50lbs for split carbs on all combos(on big tire combos only)
Add 50lbs for sheet metal intakes on NOS combos(big tires only)
Add 100lbs for Symmetrical Heads on NOS combo(big tires only)
Deduct 75lbs for use of single carb on any combo
Deduct 125lbs. for single stage plate
Deduct 100lbs for a true 10.5" slick or 275/60
BOP combos run at small block weights
XOS reserves the right to make changes to any combination if deemed necessary by the XOS staff #xosrules
 2016 X235 Rules
BODY & GLASS
* Must have working lights, stock appearing interior, carpet, door panels, factory style dash, stock floor pans, stock firewall.
-No body components, bumper add-ons, etc. permitted with the intent of increasing the distance of the front bumper for the purposes of breaking the infrared beams (i.e. no “extenders”)
TIRE. Must be mass produced. No test or one off tires
* 26x8.5x15
* 235x60x15
PN for the P235/60R15 is 17314DR2
PN for the 26.0/8.5-15 C11 is 18115
Hoosier Tires only
SUSPENSION
* No wheelie bars.
* All vehicles must retain the factory frame rails. Notching for rear tire clearance is permitted.
* Stock suspension or ladders bars only
*coilovers ok
POWER ADDERS
* Single type power adder only. All combos
NITROUS:
No multiple stages permitted.*
No progressive controllers or Digisets
No Pusher systems of any kind (No NANO or similar), No nitrous chillers (NO COLD
NITROUS)
All nitrous solenoid grounds must be grounded in engine compartment and
visible. ( in plain sight)
No "leaking" nitrous in any way in any location.
Must have perfectly round jet orifice. No modified jets
Purge plume must be entirely outside of the engine bay and
directed upward.
Big Block OEM Block Nitrous entries maximum jetting
1 jet .076
2 jets .053
8 jets .026
Small Block Nitrous entries maximum jetting
1 jet .082
2 jets .057
8 jets .028
Small Block Nitrous entries maximum jetting(8.2 Deck ONLY!!!)
1 jet .092
2 jet .065
8 jet .032
FORCED INDUCTION
* Max turbo size 76mm measured tip to tip. (no reducers allowed to achieve this size and no clipped wheels)
* You may be required at any time to remove your turbo and/or your turbo cover to be checked.
* Maximum supercharger sizes D1, V-7 JT Trim, NOVI 2000, Kenny Bell 3.6
YSI, F1A F1C allowed. see weight
* 6-71 blowers Sb only
* No gear drives
* Air to water, Air to air intercooler OR water meth injection allowed. Can only run 1 style intercooler
* A single line from the manifold to the wastegate only
* Nothing else to top of wastegate or blow off valve
EXHAUST
* Mufflers required on all entries except turbo cars.
CYLINDER HEAD / ENGINE INDUCTION
* Big block OE passenger car block.
* Big blocks limited to stock valve angle. Call or PM for approved heads.
* Cylinder heads for SB limited to, 23 degree Chevrolet, 15 degree LS, 18 degree Mopar, 20 degree Ford, OEM Ford casting 4v Modular, any 2v Modular, Trick Flow Twisted Wedge and LS 13.5 OK
* All cylinder heads must maintain the automobile OEM intake manifold bolt pattern.
* Sheet metal or tunnel ram intakes manifolds not permitted.
* Single carb or throttle body
FUEL
* Gasoline or E85 are the only fuels permitted. Methanol only allowed in a 50/50 mix with water and is considered an intercooler.
ELECTRONICS
* Any ignition or EFI permitted.
* No traction control devices of ANY kind.
* No progressive nitrous controllers allowed.
* No boost controllers allowed. Solenoids must be removed from car
* No digiset
BASE WEIGHTS
* SB naturally aspirated - 2700
* SB nitrous - 8.2 deck or modular 3000
* SB nitrous - 3050 see bottom for weights
* SB turbo - 3300
* 6 Cyl turbo - 3200
* SB turbo billet 76 - 3500
* SB YSI billet - 3350
* SB & V6cyl supercharged/Blower - 3050
* SB F1A 3100
* SB YSI and F1C(91series) 3250
* BB NA 3000
* BB nitrous 3250
*4cyl VW 1600
*4cyl turbo manual trans 2025
*4cyl turbo auto trans 2225
*Inline 6 turbo manual trans 2900
*Inline 6 turbo auto trans 3100
* No AWD vehicles
WEIGHT PENALTIES AND DEDUCTIONS
* Deduct 50lbs for 235 radial (any combo can take weight break)
* Deduct 50lbs for SBC and SBF Stockblock. No deductions for Mod and
LS Stockblock
* Deduct 50lbs for 6AL or equivalent box with no add ons
* Add 50lbs for BBF A head
* Add 50lbs for All* SB Highport, Ford TFS-R, TFS Highport
* Add 75 lbs for All SB Nitrous 20 degree high port SR20 –FT1 or T1RI or equivalent, 15* SBF and SBC Nitrous 18* and 23* raised runner heads. No turbo/ supercharger combos with these heads
With all the new heads that are coming out, we will look at them and adjust periodically.
Engine diapers are mandatory
ANY
U/S and x275 are ran with John Sears rules.
Re: Monster Mopar/Mustang? [Re: 1980volare] #2052275
04/11/16 10:50 PM
04/11/16 10:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thanks for the above post. Can you list or do you know an average ET for each class.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Monster Mopar/Mustang? [Re: POZEST] #2052310
04/11/16 11:21 PM
04/11/16 11:21 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
X235 record is 5.20s sbf nitrous, you can go rounds if you run 5.60-.30s this class will probably be faster this year
X275 4.70-80s average I'd say.
US 5.0-.20
Ols is typically a bit faster then x275.
But it depends on who shows up. Alot of fast radial cars run this local series.
Re: Monster Mopar/Mustang? [Re: POZEST] #2052349
04/11/16 11:48 PM
04/11/16 11:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Looks like we would have to weigh at least 3300lbs, same as a twin turbo car on alcohol and be down 1000hp to them, plus run on two kits..............PASS.............Insane rules. Nitrous car has NO chance. Rules allow 3.80 capable turbo cars at the weight they normally run at.........CRAZY
Re: Monster Mopar/Mustang? [Re: POZEST] #2052775
04/12/16 02:33 PM
04/12/16 02:33 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
@ 3400lbs how do you cut the .400 tree.. not a chance. Those X235 rules are something all right.
Re: Monster Mopar/Mustang? [Re: POZEST] #2052789
04/12/16 02:44 PM
04/12/16 02:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I have a customer that I think runs this series. We sold him the motor out of the Buick, as we are building a new one. Some of these rules came about AFTER he bought that motor. Seems they were concerned about how fast the Buick had been, 4 teens, that they went WAY overboard in Limited Street on the nitrous rules. Never mind the fact that we only went teens in Outlaw trim at 2600lbs.
If you look at the rules, it shows just how scared they are of a big motor.......YET they let a single stage, conventional headed big block weigh 300lbs LESS than the same combo runs in X275, where the "hitter" nitrous guys run 4.40s. Those rules make ZERO sense.
Re: Monster Mopar/Mustang? [Re: POZEST] #2052802
04/12/16 02:56 PM
04/12/16 02:56 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Drawn up for the fox body crowd. That's the only way it makes sense.
Re: Monster Mopar/Mustang? [Re: POZEST] #2052811
04/12/16 03:01 PM
04/12/16 03:01 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The body makes no difference............it's the weight limits for the power combos. In radial racing, few fox bodies are actually even Ford powered, so that's a non issue
Re: Monster Mopar/Mustang? [Re: POZEST] #2052830
04/12/16 03:20 PM
04/12/16 03:20 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
I was referring to the 235 class.. but I get your point smile
Re: Monster Mopar/Mustang? [Re: DARTH V8Я] #2053003
04/12/16 07:47 PM
04/12/16 07:47 PM
hustlin hoosier Offline
We will run the 235 class on motor. A 5.10 will win in my opinion . We ran the barracuda at their last race the "Finale at the Valley" last year and ran 4.80'S and won. The fastest car we saw was a 4.73. We have been to a couple of their events. Hopefully by race time we will be a high 40's or low 50's car.
Re: Monster Mopar/Mustang? [Re: POZEST] #2100705
06/29/16 07:47 PM
06/29/16 07:47 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Unfortunately it appears as if this portion of the race is not going to happen.
We are back to our regularly scheduled program.
