Re: 499 vs 512 low deck [Re: Ohio Joe] #2050862
04/10/16 07:34 AM
04/10/16 07:34 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Originally Posted By Ohio Joe
This has gone 5.95 with a 470 on E85
At what weight though ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 499 vs 512 low deck [Re: deaks] #2050867
04/10/16 07:57 AM
04/10/16 07:57 AM
1.5 miles west of Jacksonburg ...
Ohio Joe Offline
Ohio Joe  Offline
2950, it weighs 100 lbs less than our 66 dart.
66 Dart GT " Rat Racer"
Re: 499 vs 512 low deck [Re: Ohio Joe] #2051008
04/10/16 01:33 PM
04/10/16 01:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice........what heads........
Re: 499 vs 512 low deck [Re: Ohio Joe] #2051029
04/10/16 02:03 PM
04/10/16 02:03 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Can you tell us more about your combo
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 499 vs 512 low deck [Re: Sport440] #2051287
04/10/16 08:31 PM
04/10/16 08:31 PM
California
Moneypit6 Offline
Moneypit6  Offline
California
Why not a 499 using the same components except a compression height of 1.37? Slightly more stable compression height and slightly better rod ratio for those on the fence worrying about the 512 longevity. Seems good to me. Fits nicely between the 470 and 512.
70 Roadrunner almost ready to come off the rotisserie smile
Re: 499 vs 512 low deck [Re: Thumperdart] #2051338
04/10/16 09:50 PM
04/10/16 09:50 PM
Ohio Joe Offline
Ohio Joe  Offline
It has Indy SR'S . We call the car Spare Parts because the motor belongs to a friend who wasn't racing at the time and the tranny and vert belong to another friend . We rushed putting it together for Norwalk. To say the least we were very suprise what it ran.
Re: 499 vs 512 low deck [Re: Eric] #2051832
04/11/16 01:53 PM
04/11/16 01:53 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Who ported the heads, cam size, comp please ? I'm just about to fit a 470 in mine.
Mick
best 60ft 1.36
Re: 499 vs 512 low deck [Re: Eric] #2051899
04/11/16 03:21 PM
04/11/16 03:21 PM
an8sec70cuda Offline
I'd go w/ the 4.25" stroke.
Seems there was a discussion a while back by one of the big name builders...like Kaase or maybe Reher-Morrison, I cant remember who exactly. They basically said the rod-stroke ratio didn't really matter when it came to making power.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 499 vs 512 low deck [Re: an8sec70cuda] #2051912
04/11/16 03:32 PM
04/11/16 03:32 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
512" Built all the B/RB combinations from 431" all the way up to 517", bigger is more and .200" of rod length won't mean diddly, especially on a low/moderate RPM torque motor. Again, piston selection from all the major Piston Mfg's is all over that 451/512 1.32" Compression height slug.
If 6.535" seems short for a 4.25" stroke in a 9.98" deck, remember that there are 10X as many big block 496" Chevies with only 6.135" and 6.385" rods running around.
WIZE
In Car:
Re: 499 vs 512 low deck [Re: deaks] #2051957
04/11/16 04:44 PM
04/11/16 04:44 PM
Ohio Joe Offline
Ohio Joe  Offline
Mick,hate to say but I don't know a whole lot about the motor.i just own the body. I "think" Duwane Porter did the heads and spec ed the cam. Sorry, but that's about all I know about the motor.
Re: 499 vs 512 low deck [Re: Eric] #2052136
04/11/16 08:47 PM
04/11/16 08:47 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I went with the 499 stroked 400 block. I figured it would be easier on the engine block at high RPM (lighter weight, lower acceleration rates and loading when switching direction, less side wall thrust loading?)
Down side with the short piston might be piston rock/ring seal on the intake stroke?
You can get a 4.15" crank with the 2.20" rod journal, that will give a better selection of rods/rod lengths.
Currently using the Hughes CNC ported MW Victor heads. I did not cc the Hughes heads, but compression with 75cc should be around 12.4:1 with zero decked flat tops. I used the old 440 source stroker kit with I-Beam rods and ARP2000 bolts, and the BCR aluminum main caps with girdle.
Not too many runs on it, because of the issues with the old Victor heads. Just got it running with the new CNC heads and E-85 last year, so we'll see how this year goes?
I think the 4.25" stroke low deck is a good choice for most street/strip cars that are not going to run 7000+ RPM.
I do have the 4.25" crank in the 440 block in the convertible smile
Re: 499 vs 512 low deck [Re: Streetwize] #2052191
04/11/16 09:53 PM
04/11/16 09:53 PM
gregsdart Online content
gregsdart  Online Content
Yep!
Re: 499 vs 512 low deck [Re: Ohio Joe] #2055125
04/15/16 07:56 PM
04/15/16 07:56 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
combo is 3.90 stroke, 4.375 bore, 6.700 rod, flat top pistons with a total compression of 11.4 to 1, Cam is a comp 661 lift and 274 duration at .0050. Heads are Indy SR's that were ported by Dwayne Porter. Indy intake with a Horsepower Innovations 850 E85 carb.
Re: 499 vs 512 low deck [Re: fbs63] #2055193
04/15/16 09:46 PM
04/15/16 09:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By fbs63
One thing about the LD 512. The 1.54 rod ratio adds more thrust on the cylinder wall. I would make sure you have the block sonic tested and find a good one. No need to be worried about a short comp height. OEM engines now are all close to 1" comp height and go 200,000 miles. In your light car with the heads you have I would do a 470. Quicker rpms and your heads will support 470 cubes well.
THIS................ drive Been streetin/racing mine for almost 15 years w/the same 413 off-set stroke crank and Chevy Eagle rods and I just run junky ol E-brock home ported RPM heads and a solid roller..........
