Page 2 of 4 1 2 3 4
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048463
04/06/16 11:51 PM
04/06/16 11:51 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Why do they need Chamfering? I recently bought a Source crank expecting that to need bearing chamfering but it didn't, all the Clevite bearings fitted perfect with 0.0025 clearence on all journals. Couldn't ask for better.
Re: Stroker cranks available for the 400B block [Re: rebel] #2048522
04/07/16 12:51 AM
04/07/16 12:51 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Maybe I'm missing something but why would you order bearing before crank....just because they say it's so don't mean it is..or am I thinking wrong order bearing get crank go from there ..I would think check block order crank then get bearing and machine to spec..am I wrong in my thinking..
Re: Stroker cranks available for the 400B block [Re: earthmover] #2048543
04/07/16 01:18 AM
04/07/16 01:18 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i want to make sure the bearings especially the thrust bearing fit the aluminum caps while i have the block at the shop. i have been told sometimes the thrust bearing doesn't properly fit these caps. really doesn't matter either way as it sounds like i will have to have the crank machined for clearance anyway.
Re: Stroker cranks available for the 400B block [Re: rebel] #2048548
04/07/16 01:21 AM
04/07/16 01:21 AM
Mt Morris Michigan
Mt Morris Michigan
well, thats good to hear. i talked to source today and they told me the clevite ms876p main would have to be chamfered. they sell the chamfered bearing for something crazy like $179 a set. ouch!
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048587
04/07/16 03:06 AM
04/07/16 03:06 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
When I was chamfering bearings for an early Source crank it was only the rod bearings that needed attention. The new crank I bought was fitted up with HN bearings & they fitted up fine with no clearencing issues.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048609
04/07/16 05:23 AM
04/07/16 05:23 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have the MS 876P bearings and the info says they are narrow for clearance on all aftermarket cranks.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048628
04/07/16 07:15 AM
04/07/16 07:15 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Why are people still making the Mopar size journals...???
Re: Stroker cranks available for the 400B block [Re: Pale_Roader] #2048667
04/07/16 10:01 AM
04/07/16 10:01 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
IMO no reason NOT to go 4.25", with a 6.535" (BBC +.500") you can use the same 1.32" CH piston they make for any 451 B low deck 6.76" rod combo, everybody makes that piston. a 4.25" with 2.200 journals has BETTER block clearance than a 4.15" stroke with the B/RB mopar journals.
FWIW....the 4.15" stroke came about because it mathematically allowed any RB owner to bump to 493 cubes by boring to 4.342" reusing his 6.76" rods and using an off-the-shelf 400B piston.
WIZE
In Car:
Re: Stroker cranks available for the 400B block [Re: rebel] #2048716
04/07/16 11:05 AM
04/07/16 11:05 AM
Mt Morris Michigan
Mt Morris Michigan
yeah, hn. the n is for narrow. thats how king does it. would have bought the king mains but they dont offer a full groove.
Re: Stroker cranks available for the 400B block [Re: deaks] #2048721
04/07/16 11:09 AM
04/07/16 11:09 AM
Mt Morris Michigan
Mt Morris Michigan
i hope that is correct. my save me alittle
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048818
04/07/16 01:42 PM
04/07/16 01:42 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
The 4.15 piston is only 468g though.
best 60ft 1.36
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048827
04/07/16 01:57 PM
04/07/16 01:57 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
I just had Ohio crank take a 440 4.250 stroke crank and make me a 400 4.375 stroke with 2.2 rod journals. When it was all said and done I have around $700 in the crank. I started off with a new k1 crank
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048837
04/07/16 02:16 PM
04/07/16 02:16 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
ohio crank will do what ever you want,i have a 4.500 stoke,chevy rod 2.20,,400 mains,knife edge,counter weights cut down,lighten,in a 400
Re: Stroker cranks available for the 400B block [Re: dart games] #2048844
04/07/16 02:25 PM
04/07/16 02:25 PM
Which type, steel or aluminum, H beam or I beam rods did you use in that motor? How much block grinding for rod clearances was needed with that stroke? I haven't ran a 4.375 stroke in a 400 yet, much less a 4.500 bow Thanks in adavnce for the answers thumbs
Re: Stroker cranks available for the 400B block [Re: deaks] #2048889
04/07/16 03:21 PM
04/07/16 03:21 PM
Pittsburgh PA
Eric Offline
Happy Birthday Eric  Offline
Pittsburgh PA
Are you using the Mahle pistons?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Stroker cranks available for the 400B block [Re: deaks] #2048898
04/07/16 03:40 PM
04/07/16 03:40 PM
Mt Morris Michigan
Mt Morris Michigan
the mahles i would like to use are 512g. these are 1.350x4.375
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048956
04/07/16 04:37 PM
04/07/16 04:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you plan on purchasing Mahles, price check a few sources. JEGS was $100 less than Summit when I ordered mine.
Re: Stroker cranks available for the 400B block [Re: GY3] #2048965
04/07/16 04:41 PM
04/07/16 04:41 PM
Mt Morris Michigan
Mt Morris Michigan
i found them for 607 . not sure if that price is still current.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048975
04/07/16 04:54 PM
04/07/16 04:54 PM
Pittsburgh PA
Eric Offline
Pittsburgh PA
BIG BLOCK MOPAR (B) / 383, 400 Flat Top
1.5, 1.5, 3.0mm File Fit Performance Ring Set included 72cc 80cc 84cc
499 4.375 4.150 6.760 1.120R 0.990 -8cc 467 12.4 11.4 11.0 4032 0.350 0.0041 0.0049 BBM120375F08
Compression Heights with "R" INCLUDE Oil Support Rails
These are what I was looking at...
Re: Stroker cranks available for the 400B block [Re: Eric] #2049005
04/07/16 05:40 PM
04/07/16 05:40 PM
Mt Morris Michigan
Mt Morris Michigan
i looked at those too. I was told may not be a good choice for a street/strip deal.
Page 2 of 4 1 2 3 4
