Re: Custom gussets nhra legal ?
[Re: Chryco69]
#2050737
04/10/16 12:45 AM
04/10/16 12:45 AM
Posts: 11,760 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would say it depends. No clue what you have in mind. Rule book says on an incomplete (max. 25%) weld, you need two 1.750 x 1.750 x .110 gussets per affected joint. "gussets may have a maximum of one 1/2" hole and two 5/16" holes." Or 3/4" tube gussets at least 4" long. If the joint is welded 100% and doesn't require a gusset per the spec, you can do whatever you want, cobwebs, designs, skeletonized, etc.
[Re: CMcAllister]
#2050899
04/10/16 11:00 AM
04/10/16 11:00 AM
Posts: 22,770 Bitopia
jcc
Bitopia
I would say it depends. No clue what you have in mind. Rule book says on an incomplete (max. 25%) weld, you need two 1.750 x 1.750 x .110 gussets per affected joint. "gussets may have a maximum of one 1/2" hole and two 5/16" holes." Or 3/4" tube gussets at least 4" long. If the joint is welded 100% and doesn't require a gusset per the spec, you can do whatever you want, cobwebs, designs, skeletonized, etc. Pentastars,
[Re: jcc]
#2050999
04/10/16 01:18 PM
04/10/16 01:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would say it depends. No clue what you have in mind. Rule book says on an incomplete (max. 25%) weld, you need two 1.750 x 1.750 x .110 gussets per affected joint. "gussets may have a maximum of one 1/2" hole and two 5/16" holes." Or 3/4" tube gussets at least 4" long. If the joint is welded 100% and doesn't require a gusset per the spec, you can do whatever you want, cobwebs, designs, skeletonized, etc. Pentastars, I've seen those and kind of thought that might be where this was headed. If the joint is 100% welded and/or a gusset is not required by the spec you are building to, it should be OK. Otherwise, I would want a division tech director or the guy who will be doing the cert to tell me they're OK before I weld them in.
