winches in trailers?pics? #204866
01/26/09 02:38 PM
01/26/09 02:38 PM
Stratford,Ct
7sec.cuda Offline OP
Stratford,Ct
i know i asked this before but can i see some pics of how you have your winches mounted in your trailers thanks
Re: winches in trailers?pics? [Re: 7sec.cuda] #204867
01/26/09 06:27 PM
01/26/09 06:27 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Re: winches in trailers?pics? [Re: bonefish] #204868
01/26/09 06:47 PM
01/26/09 06:47 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I don't think this is what you looking for but here's the only picture I have. We used some 1/8 steel plates to mount to the frame and we put a top on it so I can still use the floor space to store stuff.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: winches in trailers?pics? [Re: WadeMetzinger] #204869
01/26/09 06:56 PM
01/26/09 06:56 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
This is in my open trailer
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: winches in trailers?pics? [Re: bigdad] #204870
01/26/09 06:58 PM
01/26/09 06:58 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
out side the box,
I have no pics of the enclosed trailers winch
Re: winches in trailers?pics? [Re: bigdad] #204871
01/26/09 07:31 PM
01/26/09 07:31 PM
So Dak
GOLDENCOMMANDO Offline
So Dak
out side the box,
Hey!! That looks just like the one on mine!!
Re: winches in trailers?pics? [Re: GOLDENCOMMANDO] #204872
01/26/09 07:50 PM
01/26/09 07:50 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
out side the box,
Yep, looks familar huh
Re: winches in trailers?pics? [Re: 7sec.cuda] #204873
01/26/09 07:50 PM
01/26/09 07:50 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
pull one pin and the wimch slides out..
Re: winches in trailers?pics? [Re: smokinwoody] #204874
01/26/09 08:46 PM
01/26/09 08:46 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Re: winches in trailers?pics? [Re: Diego_Ted] #204875
01/26/09 08:54 PM
01/26/09 08:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have mine mounted in the bottom of a cabinet on
the other side of the wall, you can see the hook
at the wall, the button is hanging there
Re: winches in trailers?pics? [Re: Diego_Ted] #204876
01/26/09 09:00 PM
01/26/09 09:00 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
only pic I got is too big.
but I made a steel box big enough for my winch and an Optima battery and mounted it flush/ below the floor between 2 X members. I extended the remote control so it plugs in near the wall light switch, and of course the battery is hooked to the charging system of my tow vehicles.
the box is also vented in case of heavy fumes being in the low spot of the trailer, and the likelihood of sparks from the winch motor.
Its far back, so I dont have to step over the cable or wind it up all the time. I had the winch in the front lower cabinets of my old trailer, and that gets old real fast.
Re: winches in trailers?pics? [Re: MR_P_BODY] #204877
01/26/09 09:00 PM
01/26/09 09:00 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
anyone got any more pics of side mounted winches?
Re: winches in trailers?pics? [Re: bonefish] #204878
01/26/09 09:09 PM
01/26/09 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry no pic, it was on my last trailer. I had the
winch mounted to the floor (on the side) then had a
5/8" ID tube mounted to a cross bar(under the trailer)
that was flush with the floor. On the cable I had
a pulley with a 5/8"rod welded to the bracket
on the pulley... drop the pulley in the hole and I
was ready
Re: winches in trailers?pics? [Re: bonefish] #204879
01/26/09 09:59 PM
01/26/09 09:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
NO picture but thats how mine is, mounted on drivers side wall floor area just ahead of the car. Installed a d-ring at the center floor with a removable block pulley. Pulls the car in straight and you don't have the cable in your way.
Re: winches in trailers?pics? [Re: MR_P_BODY] #204880
01/26/09 10:01 PM
01/26/09 10:01 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Mine is in the cabinet
The original owner of the trailer had some sort of rail and loaded everything to one side. That's why there are 2 openings with rollers. I damaged a cable and the tensioner with the cable winding up on one side of the spool so I relocated the winch to center it.
Re: winches in trailers?pics? [Re: Bigcube] #204881
01/26/09 11:20 PM
01/26/09 11:20 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
ol fashioned way
Re: winches in trailers?pics? [Re: sogtx] #204882
01/26/09 11:31 PM
01/26/09 11:31 PM
rowin4 Offline
rowin4  Offline
Gee, if you put some tires on that thing it might roll even easier. lol
Re: winches in trailers?pics? [Re: rowin4] #204883
01/27/09 12:05 AM
01/27/09 12:05 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I could show a picture but would be nothing to see. My S5000 Superwinch is simply bolted up in the front of my trailer under the cabinet. Just the hook sticking out when in. We used a piece of 1/4" steel under the floor as a large "washer" so to speak.
Re: winches in trailers?pics? [Re: Al_Alguire] #204884
01/27/09 01:54 AM
01/27/09 01:54 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Mine is mounted next to the roadside wall. Battery is in box under the floor next to it. D-ring in the middle of the floor has a removable pulley I got at the local hardware store.
Re: winches in trailers?pics? [Re: G_bob] #204885
01/27/09 01:55 AM
01/27/09 01:55 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
2nd pic.
