Cuda Dash / 4-spd Pedals / Steering Column Install.....
#2048396
04/06/16 10:43 PM
04/06/16 10:43 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Getting ready to install the dash, pedals, steering column. Put in the dash/firewall insulation already. What order? Pedals, dash, column?
Anyone have any pictures?
Admiration For Multiple Carburetor Vehicles...
Re: Cuda Dash / 4-spd Pedals / Steering Column Install.....
[Re: moparmarks]
#2048684
04/07/16 10:24 AM
04/07/16 10:24 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I do the pedals first then dash and then column. I agree. Pedals have cross braces that are hard to get to once dash is in. I'll install master cylinder before dash too, as its easier to get to upper nuts. Then I'll install assembled dash (wiring and all) with a helper. Column last. In fact, you can probably keep the column out while doing most of interior. Makes a bit more room to work around.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Stewpar]
#2050013
04/08/16 09:29 PM
04/08/16 09:29 PM
Posts: 3,115 Sacramento,California
JRepucci
Pedals, Dash, Column...remove the studs for the column from the pedal assembly. Hang the dash on the outer bolts and push the frame up into place.
Before the dash...
heater box, insulation, vent box, brake system, clutch linkage, emergency brake...
