Re: Stroker cranks available for the 400B block
[Re: mopar dave]
#2048609
04/07/16 05:23 AM
04/07/16 05:23 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I have the MS 876P bearings and the info says they are narrow for clearance on all aftermarket cranks. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Pale_Roader]
#2048667
04/07/16 10:01 AM
04/07/16 10:01 AM
Posts: 9,893 Weddington, N.C.
Streetwize
Weddington, N.C.
IMO no reason NOT to go 4.25", with a 6.535" (BBC +.500") you can use the same 1.32" CH piston they make for any 451 B low deck 6.76" rod combo, everybody makes that piston. a 4.25" with 2.200 journals has BETTER block clearance than a 4.15" stroke with the B/RB mopar journals.
FWIW....the 4.15" stroke came about because it mathematically allowed any RB owner to bump to 493 cubes by boring to 4.342" reusing his 6.76" rods and using an off-the-shelf 400B piston.
[Re: mopar dave]
#2048818
04/07/16 01:42 PM
04/07/16 01:42 PM
deaks
robin hood country
The 4.15 piston is only 468g though.
[Re: mopar dave]
#2048837
04/07/16 02:16 PM
04/07/16 02:16 PM
Posts: 682 st.louis,mo.
dart games
st.louis,mo.
ohio crank will do what ever you want,i have a 4.500 stoke,chevy rod 2.20,,400 mains,knife edge,counter weights cut down,lighten,in a 400
[Re: dart games]
#2048844
04/07/16 02:25 PM
04/07/16 02:25 PM
Posts: 43,326 Bend,OR USA
Cab_Burge
ohio crank will do what ever you want,i have a 4.500 stoke,chevy rod 2.20,,400 mains,knife edge,counter weights cut down,lighten,in a 400 Which type, steel or aluminum, H beam or I beam rods did you use in that motor? How much block grinding for rod clearances was needed with that stroke? I haven't ran a 4.375 stroke in a 400 yet, much less a 4.500 ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif) Thanks in adavnce for the answers ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: deaks]
#2048889
04/07/16 03:21 PM
04/07/16 03:21 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
The 4.15 piston is only 468g though. Are you using the Mahle pistons?
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: mopar dave]
#2048975
04/07/16 04:54 PM
04/07/16 04:54 PM
Eric
Pittsburgh PA
BIG BLOCK MOPAR (B) / 383, 400 Flat Top 1.5, 1.5, 3.0mm File Fit Performance Ring Set included 72cc 80cc 84cc 499 4.375 4.150 6.760 1.120R 0.990 -8cc 467 12.4 11.4 11.0 4032 0.350 0.0041 0.0049 BBM120375F08 Compression Heights with "R" INCLUDE Oil Support Rails
These are what I was looking at...
