Re: 727's and power?
[Re: rickseeman]
#2047276
04/05/16 06:34 PM
04/05/16 06:34 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Even Ma Mopar knows. The 2015 Drag Pak Challengers have a TH400. Seriously? Hmmm learn something new every day.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: dthemi]
#2047295
04/05/16 06:58 PM
04/05/16 06:58 PM
DARTH V8Я
Its a TRAP!
Well I did know that the Torqueflite 8-speed is actually a disguised BMW ZF8HP 8-speed.
[Re: DARTH V8Я]
#2047302
04/05/16 07:12 PM
04/05/16 07:12 PM
Posts: 6,151 Melbourne , Australia
LA360
If anyone was going to need aftermarket 727 cases, it would be Pro Trans. 727 cases will eventually become very hard to come by, so a new case would come out of necessity. It would however, have some modifications to your standard 727 case.
Alan Jones
[Re: Monte_Smith]
#2047354
04/05/16 08:17 PM
04/05/16 08:17 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I agree with this. Does every car need a glide or a Turbo, of course not..........But what really pisses me off is when you get chastised for making the switch, by some purist, who has his head so far somewhere they can't see the light. They tell you what you should NOT have done, but offer up no other suggestions.
Wonder if Jim Kinnett had to put up with that crap when he had a 12 bolt under his SS/AA car. What about the loads of Modified and Gas guys who ran Top Loaders because the HEMI boxes eat main clusters. Wonder if they had to hear that crap Haven't heard that name in a WHILE! Frank, at Kinnetts did machine work for me in the 80's. I even bought some of his old hemi stuff. They cut the blocks so low on the deck, and lighten them so much you had to run more stop leak than water lol.
[Re: an8sec70cuda]
#2047445
04/05/16 10:30 PM
04/05/16 10:30 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Just adding that my car is somewhere in the 1050-1100 hp range and has a 727. Good steel planetary setup, billet steel drum, and a bolt in sprag. That's about it. It's held up so far. 8.90s at 150 mph at 3900 lbs.
If/when it breaks, I'll be pricing my options. Are using a Transbrake??
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: rickseeman]
#2047481
04/05/16 11:01 PM
04/05/16 11:01 PM
Posts: 13,204 aZLiViN
J_BODY
aZLiViN
Even Ma Mopar knows. The 2015 Drag Pak Challengers have a TH400. ...and there's a lil trans shop in Cal that can spin that around: OUTPUT SHAFTS== "you can now install a Pro Trans 727-904 trans in a new drag pack Challenger that comes from the factory with a TH400. It is the same overall length as the TH400 and have TH400 input and output spline. It is also set up to use your existing Reid Racing bell housing that came on the TH400. Just bolt on and install into your car" No opinion.... just keeping it interesting. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: dthemi]
#2047519
04/05/16 11:26 PM
04/05/16 11:26 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
If i could get a 4l80E to work with my pushbuttons, i'd have one in next week. i have a '65 cable shift 727. on;y thing that hasn't been upgraded are the shafts. it's a 4,500lb car that makes just under 640lbft....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: dthemi]
#2047577
04/06/16 12:25 AM
04/06/16 12:25 AM
Posts: 9,897 MI, usa
dvw
MI, usa
As we all know most Mopar's don't have a good enough cylinder head to make enough power to break a 727 anyway, right? If I got to the point where I was braking stuff I'd have no problem switching to a 400 / 9" axle. There are 4 of us that hang out and race low 9/high 8 second Mopar's. They range in race trim from 3000-3750lbs. The two lightest are Glides, mine is a 727, the third is 727 w/brake, the heaviest. Mine is next heaviest but is a foot brake, the glides have trans brakes. Mine by far has the most passes. Both the aftermarket glides have broken expensive (in my book over $600) aftermarket parts after being modified. Mine has an aluminum drum ($600) and a Super Sprag ($200), the rest is used stuff. The 727 with a brake has a good drum ($600), super sprag ($200) and a steel front planet ($450). Both 727's hit the stock aluminum planet pretty good, the trans brake car rolled the stock sprag. Mine got another stock planet as the first one went 250+ passes. Neither have hurt anything costly after the above mentioned mods. I believe a M&M 400 would be awesome. It would also cost more than I have in my motor. Doug
[Re: dthemi]
#2047579
04/06/16 12:33 AM
04/06/16 12:33 AM
slammedR/T
My old combo 408 with 93 pump gas, single 200 shot and foot brake went 9.26 at 145mph and I'm rocking a 727. A Reid ultra case th400 will be in my future plans but for now I hope to get away with a transbrake in my 727 for awhile till I can build and get the parts for the th400 swap.
[Re: slammedR/T]
#2047763
04/06/16 11:06 AM
04/06/16 11:06 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
If/when it breaks, I'll be pricing my options. Are using a Transbrake?? No. The trans has a brake in it, but I don't use it. Always footbraked the car.
[Re: MR_P_BODY]
#2047853
04/06/16 12:19 PM
04/06/16 12:19 PM
Posts: 2,692 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Yep..........and previous Drag Packs came with glides. Think they all have 9" Ford rears They have a fab 9"... at least in the design builds Fab 9" is illegal. Can't have that.
2011 Drag Pak Challenger
[Re: rickseeman]
#2047854
04/06/16 12:20 PM
04/06/16 12:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yep..........and previous Drag Packs came with glides. Think they all have 9" Ford rears They have a fab 9"... at least in the design builds Fab 9" is illegal. Can't have that. That was what I seen on the first drag pac car ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: dthemi]
#2047860
04/06/16 12:27 PM
04/06/16 12:27 PM
DARTH V8Я
Its a TRAP!
They call it a 8 & 4 quarter diff..
[Re: dthemi]
#2047901
04/06/16 01:05 PM
04/06/16 01:05 PM
Posts: 1,238 North Central, Indiana
Roughbird72
Being the Drag Paks are not a standard production vehicle they can probably designate the differentials how ever they please. If the 9" isn't legal how do they get by running glides & T400s?
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2047935
04/06/16 01:45 PM
04/06/16 01:45 PM
Posts: 11,840 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Being the Drag Paks are not a standard production vehicle they can probably designate the differentials how ever they please. If the 9" isn't legal how do they get by running glides & T400s? It's legal if it was approved and installed at the factory or contractor when the car was built. Probably has a Mopar part number also. "Special production run" approved by NHRA. The new FS classes don't follow traditional Stock rules.
