Fender interchange
#2046910
04/05/16 09:29 AM
04/05/16 09:29 AM
Posts: 1,487 STL
cdstl
STL
A neighbor kid bought a '92 or '93 D150. I'm not sure which but it has the "big" grill on it. I was at the JY and there was an '87 there with pristine front fenders on it.
How do the '87 fenders fit up with the grill on a '92?
Is my question clear as mud?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Fender interchange
[Re: cdstl]
#2046925
04/05/16 10:00 AM
04/05/16 10:00 AM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
fenders are the same 81-93
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
[Re: cdstl]
#2046993
04/05/16 11:59 AM
04/05/16 11:59 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
here is my '91. the passenger fender is off an '85, and the driver's is a '91. same same.
1981 Dodge D150 360 auto
[Re: cdstl]
#2047200
04/05/16 04:13 PM
04/05/16 04:13 PM
Posts: 1,487 STL
cdstl
STL
Good deal, thanks guys. While we're on the subject, are the hoods all the same too?
[Re: ViperDave]
#2048880
04/07/16 03:11 PM
04/07/16 03:11 PM
Posts: 3,344 Central TX
roe
Central TX
Will the grill from the later trucks bolt up and fit an 89?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#2048893
04/07/16 03:25 PM
04/07/16 03:25 PM
ViperDave
enfield, CT
Will the grill from the later trucks bolt up and fit an 89? In order to do it right you need the grille, core support, and lower filler panel. The headlight location is different. Some people do cut the core support to move the headlight mounts. The lower filler panel has a different shape to match the different grills.
[Re: ViperDave]
#2050076
04/08/16 11:40 PM
04/08/16 11:40 PM
roe
Central TX
Will the grill from the later trucks bolt up and fit an 89? In order to do it right you need the grille, core support, and lower filler panel. The headlight location is different. Some people do cut the core support to move the headlight mounts. The lower filler panel has a different shape to match the different grills. So it requires some cutting and welding? Is there a way to do it wrong?
[Re: cdstl]
#2050283
04/09/16 11:01 AM
04/09/16 11:01 AM
ViperDave
enfield, CT
the core support is bolt in.
The wrong or hack way is to cut the old style core support for the new headlight location
[Re: ViperDave]
#2050436
04/09/16 03:22 PM
04/09/16 03:22 PM
roe
Central TX
The wrong or hack way is to cut the old style core support for the new headlight location Ahhhh....I think I saw a thread on here some time ago with someone changing theirs over. I'll see if I can find it.
