The reason I ask is that it is a very greasy housing under a really rusted up car and when cleaned up has little to no pitting whatsoever. (A little on one tube)
The housing is in better shape than the 65 housing I already have for the Coronet. I need something that is slightly narrower to fit the aluminum slots and slicks on the rear without anything hitting the outer wheel house. Maybe I need to just set them side by side and check everything out...
running outside....
Alright I measured from axle flange to axle flange:
63 Dodge is 53 and 5/16
65 Dodge is 54 and 5/16
looking at the available spline on the factory 65 axles they may be about 1/8" too long on each one. The axles I got from Cass for the Dart and Satellite were splined much deeper than stock. It should work fine with aftermarket axles...
1st pic is the 63 axles...
2nd pic is the 63 housing width...
3rd pic is the 65 housing width...
4th pic is the 65 axles...
