Page 1 of 3 1 2 3
molnar crank and rods machined quality? #2045935
04/04/16 01:35 AM
04/04/16 01:35 AM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
anyone who has built an engine using molnar crank and rods, i would like to know how the machining tolerances were as far as where your bearing clearances ended up at? did you use standard bearing and get the clearances you wanted or did you end up tight or loose? thanks
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046094
04/04/16 10:31 AM
04/04/16 10:31 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
You could ask Tom himself about machining tolerances. His username is MT-Tom
I just ordered a crank from Molnar myself but haven't received it yet.
Re: molnar crank and rods machined quality? [Re: DGS] #2046106
04/04/16 10:55 AM
04/04/16 10:55 AM
Mt Morris Michigan
Mt Morris Michigan
i need to get some main bearings to see how they fit the aluminum caps as my block is in the shop. im thinking about ordering bearings +1 over size for extra clearance. this may save paying for machine work on crank. i need at least .003" clearance on the mains any how.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046107
04/04/16 10:55 AM
04/04/16 10:55 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I purchased a Molner Crank from Todd at Competition Wedge Engines who was recommended by folks this site. He balanced and measured everything up on the crank. I measured everything on the block and was able to spec the bearings. I did buy a couple of the half increment bearings (I think that is what they are called), just in case. Everything came out perfect. I don't recall all the measurements as I assembled the block last year.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: molnar crank and rods machined quality? [Re: RoadRunner] #2046114
04/04/16 11:08 AM
04/04/16 11:08 AM
Mt Morris Michigan
Mt Morris Michigan
i understand bearing clearance will be tight with std bearings using molnar crank and rods. thanks
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046120
04/04/16 11:16 AM
04/04/16 11:16 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I just installed a stroker kit that I ordered from Ray Barton. It had Molnar crank and rods. The specs were good.
Master, again and still
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046230
04/04/16 01:41 PM
04/04/16 01:41 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Are the caps already fit to the block?
Re: molnar crank and rods machined quality? [Re: JohnRR] #2046234
04/04/16 01:45 PM
04/04/16 01:45 PM
Mt Morris Michigan
Mt Morris Michigan
no they are not. i still have to drop off the caps.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046239
04/04/16 01:53 PM
04/04/16 01:53 PM
JohnRR Offline
JohnRR  Offline
Then buy your bearings and drop them off, along with the crank, and have the shop set your clearance .
Re: molnar crank and rods machined quality? [Re: JohnRR] #2046243
04/04/16 01:57 PM
04/04/16 01:57 PM
Mt Morris Michigan
Mt Morris Michigan
well, thats been my idea. just trying to possibly save on extra machine work if thats possible.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046258
04/04/16 02:12 PM
04/04/16 02:12 PM
JohnRR Offline
JohnRR  Offline
He can/should set the clearance when he fits the caps, no machining needed on the crank unless there is something wrong with the crank specs ...
Re: molnar crank and rods machined quality? [Re: JohnRR] #2046293
04/04/16 02:56 PM
04/04/16 02:56 PM
Mt Morris Michigan
Mt Morris Michigan
ok, sounds good. fixes that issue.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046340
04/04/16 03:58 PM
04/04/16 03:58 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
So would you order bearings together with crank/rods (standard size?) or separately?
Re: molnar crank and rods machined quality? [Re: DGS] #2046356
04/04/16 04:19 PM
04/04/16 04:19 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Not to get off track but I see your from Graz Austria DGS.
I worked for magna there a few times
Never though I see a mopar enthusiast from there.
beer
Re: molnar crank and rods machined quality? [Re: The Shadow] #2046370
04/04/16 04:27 PM
04/04/16 04:27 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
beer
That's funny, when I was still in college I used to work there over the summer wink
Re: molnar crank and rods machined quality? [Re: DGS] #2046405
04/04/16 05:15 PM
04/04/16 05:15 PM
Mt Morris Michigan
Mt Morris Michigan
No. Just ordered all bearings today. Went with king for the cam and rods. They are a h bearing. Clevite p bearing with full groove for mains. Yet to buy crank and rods. Have not made up my mind on the molnar stuff yet. Looking for excellents in machining if that exists.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046436
04/04/16 06:02 PM
04/04/16 06:02 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I'm thinking about mb5116hp bearings for the mains and cr808hpn for the rods (both from king).
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046447
04/04/16 06:13 PM
04/04/16 06:13 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My machinist was amazed at the quality!
My 4.25" crank and 7.1" rods get beat on almost daily in my 505.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2046484
04/04/16 07:00 PM
04/04/16 07:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I just checked all my Molnar rods this weekend. All pin bores were with-in .0001", all rods with bearings installed were +/- .0002" but I did not measure the rods and bearings separately. Clearance depends on what your crank is. Mine would have been .0021-.0022 with a standard 2.2000" journal with a coated Clevite 743HN CL77. I have no idea how thick the coating is as they were done before I received them. Total weights were with-in .9 gram except one 1.4 gram.
Doug
Re: molnar crank and rods machined quality? [Re: DGS] #2046512
04/04/16 07:16 PM
04/04/16 07:16 PM
Mt Morris Michigan
Mt Morris Michigan
cr808hpn is what i ordere. Fits 2.200 journal. 533hp for the cam if i remember correctly.
Page 1 of 3 1 2 3
