Started to build this thing 2 years ago, and got distracted with other engines, and projects. I even tried to sell all the parts at a good deal for someone, to no avail.
So now I'm going to put it together and see what it makes. Then find a chassis or rail for it when I'm done.
The motor is a 572 roots blown hemi for either alky, or C85
The parts are all new, except for the head castings,and having been sitting around the shop for a couple years now.
KB block, with standard height 54.5 tunnel, 1/2" studs and double side bolts. 4.507 bore.
Bryant, rem finished, center weighted, BBC rod X Chry main.
Oliver max 7.1 rods
C+A Ross 11:1 piston with a dikes top ring
Mild solid roller
jesel 1" tie bar TS tappets.
1/2 to 7/16 pushrods
Stage V big valve heads with moldstar 90 seats, Ti intakes, and inconel ex.
T+D rockers 1.7/1.6
Indy blower manifold
Milodon gear drive
RCD oil pump, and olsen dragster pan
littlefield 14/71 blower standard helix, single strip, cast anodized rotor.
BAU progressive linkage hat
8 160# Bosch alky injectors in the top, and 8 in the manifold
Waterman little bertha pump cam driven.
RCD trigger, hub, and magnetic wheel.
FAST EFI
All the efi stuff came from Rich at fastman.
The plan is to have 2 separate programs for either C85, or Alky.
Planning for 15-20 pounds of boost, and hoping it's north of 1500.
![](http://i123.photobucket.com/albums/o312/dthemi/DSC01538_zpsvcjt5zus.jpg)
![](http://i123.photobucket.com/albums/o312/dthemi/DSC01525_zps70aqsww6.jpg)
![](http://i123.photobucket.com/albums/o312/dthemi/DSC01524_zpsq3nfvpwd.jpg)
![](http://i123.photobucket.com/albums/o312/dthemi/DSC01520_zpsvadxzezv.jpg)
![](http://i123.photobucket.com/albums/o312/dthemi/DSC01522_zps4ey3lv7y.jpg)
![](http://i123.photobucket.com/albums/o312/dthemi/DSC01541_zpsmht6kz06.jpg)
![](http://i123.photobucket.com/albums/o312/dthemi/DSC01540_zpsgdlkagye.jpg)
