Blown 572 finally #2044579
04/02/16 05:39 PM
04/02/16 05:39 PM
back in Georgia
dthemi Offline OP
dthemi  Offline OP
back in Georgia
Started to build this thing 2 years ago, and got distracted with other engines, and projects. I even tried to sell all the parts at a good deal for someone, to no avail.
So now I'm going to put it together and see what it makes. Then find a chassis or rail for it when I'm done.
The motor is a 572 roots blown hemi for either alky, or C85
The parts are all new, except for the head castings,and having been sitting around the shop for a couple years now.
KB block, with standard height 54.5 tunnel, 1/2" studs and double side bolts. 4.507 bore.
Bryant, rem finished, center weighted, BBC rod X Chry main.
Oliver max 7.1 rods
C+A Ross 11:1 piston with a dikes top ring
Mild solid roller
jesel 1" tie bar TS tappets.
1/2 to 7/16 pushrods
Stage V big valve heads with moldstar 90 seats, Ti intakes, and inconel ex.
T+D rockers 1.7/1.6
Indy blower manifold
Milodon gear drive
RCD oil pump, and olsen dragster pan
littlefield 14/71 blower standard helix, single strip, cast anodized rotor.
BAU progressive linkage hat
8 160# Bosch alky injectors in the top, and 8 in the manifold
Waterman little bertha pump cam driven.
RCD trigger, hub, and magnetic wheel.
FAST EFI
All the efi stuff came from Rich at fastman.
The plan is to have 2 separate programs for either C85, or Alky.
Planning for 15-20 pounds of boost, and hoping it's north of 1500.
Re: Blown 572 finally [Re: dthemi] #2044587
04/02/16 05:45 PM
04/02/16 05:45 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Looks cool!Do you sand the valve pockets at all on the pistons?
Re: Blown 572 finally [Re: dthemi] #2044605
04/02/16 06:03 PM
04/02/16 06:03 PM
back in Georgia
dthemi Offline OP
dthemi  Offline OP
back in Georgia
No, C85 and alky aren't prone to detonate, so I didn't bother.
Re: Blown 572 finally [Re: dthemi] #2044802
04/02/16 10:31 PM
04/02/16 10:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
It looks pretty sweet. Did you finally get your KB block.
Re: Blown 572 finally [Re: dthemi] #2044803
04/02/16 10:31 PM
04/02/16 10:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Re: Blown 572 finally [Re: dthemi] #2044809
04/02/16 10:36 PM
04/02/16 10:36 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Doesn't look like you should have any problem reaching your goal. Nice build.
[image][/image]
Re: Blown 572 finally [Re: dthemi] #2044848
04/02/16 11:02 PM
04/02/16 11:02 PM
regina sask
N
nitrousr Offline
nitrousr  Offline
N
regina sask
Will be following with interest, as we are contemplating a switch from the procharger to a roots/alcohol deal. Good luck with the build.
Re: Blown 572 finally [Re: dthemi] #2044980
04/03/16 01:29 AM
04/03/16 01:29 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Just off to the toilet,, back soon smile
1963 Plymouth Max Wedge
1971 Barracuda
Re: Blown 572 finally [Re: nitrousr] #2044985
04/03/16 01:38 AM
04/03/16 01:38 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
north of 1500 ??
only 300 more than the N/A one you built for me ???
home of the
Sox and Martin Hemi Duster
Re: Blown 572 finally [Re: dthemi] #2044998
04/03/16 01:54 AM
04/03/16 01:54 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Let me know when you're ready and I'll send you an XFI program for that beast.
Rich Nedbal
Re: Blown 572 finally [Re: dthemi] #2045117
04/03/16 09:52 AM
04/03/16 09:52 AM
back in Georgia
dthemi Offline OP
dthemi  Offline OP
back in Georgia
Hey Fred! How the heii are ya man? I'd rather be less hopeful about power, than suffer from disappointment lol.
Rich, that would be a HUGE help towards getting it right, and not cooking something in the process. I may have to swap the injector wiring back to standard firing order, as the cam isn't 4/7 swap. Not sure what's the correct way to do that.
I still haven't bought a regulator, and I'm glad, as it appears they just keep getting nicer the longer I wait. Any favorite, for a 15 gpm pump ?
Re: Blown 572 finally [Re: dthemi] #2045219
04/03/16 12:36 PM
04/03/16 12:36 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
If you are going to run methanol you'll have to use a mechanical fuel pump and a regulator built for methanol. It's a matter of being able to maintain the EFI fuel pressure at the high methanol flow rates. And of course all the fuel lines have to be PTFE lined. Finally, if you use a cylinder top lube for the alky, make sure you use one that will not damage the O2 sensor. Most are not compatible - just check.
Swapping pins in the injector connector is pretty easy with several videos on YouTube.
Re: Blown 572 finally [Re: dthemi] #2045278
04/03/16 01:46 PM
04/03/16 01:46 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You should be able to change injector firing order in the set up tables.
Cool build.
Re: Blown 572 finally [Re: camastomcat] #2045370
04/03/16 02:45 PM
04/03/16 02:45 PM
back in Georgia
dthemi Offline OP
dthemi  Offline OP
back in Georgia
Sorry, yes I got both, and bought another one that had been made I think like 7-8 years ago and was never used.
The tall deck KB for my 670 nitrous predator is at Wj's getting honed, and clearanced right now. I have every single part for that one on the shelf. I'll start on it as soon as I finish this one.
Re: Blown 572 finally [Re: Mopar_Rich] #2045388
04/03/16 02:52 PM
04/03/16 02:52 PM
back in Georgia
dthemi Offline OP
dthemi  Offline OP
back in Georgia
The pump is a mechanical waterman alky little bertha, so no worries there. Just have to choose a good bypass reg. Either magna, or aero I'm thinking.
I've never seen an O2 safe top lube. Do you know of one?
I'll swap pins for wire routing issues, instead of changing it in the program.
Also Rich, I'd still like to have an idle program for gasoline, so after running it on either alcohol, i can swap to gas to dry the motor out, and protect the fuel system.Thanks for the support Rich.
Re: Blown 572 finally [Re: dthemi] #2045410
04/03/16 03:10 PM
04/03/16 03:10 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
bow
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Blown 572 finally [Re: dthemi] #2045483
04/03/16 04:08 PM
04/03/16 04:08 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Klotz KL-107 is O2 safe
Re: Blown 572 finally [Re: dthemi] #2045555
04/03/16 05:21 PM
04/03/16 05:21 PM
back in Georgia
dthemi Offline OP
dthemi  Offline OP
back in Georgia
Cool, thanks Rich I'll use that. The C85 is the least corrosive ethanol fuel I've yet seen. When it evaporates it leaves a yellow oily residue, instead of the usual chalky mess.
Re: Blown 572 finally [Re: dthemi] #2045623
04/03/16 07:19 PM
04/03/16 07:19 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Methanol is a whole different thing.
Re: Blown 572 finally [Re: dthemi] #2045656
04/03/16 08:33 PM
04/03/16 08:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Should be a fun/exciting ride.............. thumbs
