Cooling System Pressure Test Question #204557
01/25/09 10:51 PM
01/25/09 10:51 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
When doing a hand pump type pressure test on the cooling system, thermostat removed, engine cold, how long should the system hold 15lbs of pressure to be considered tight?
Re: Cooling System Pressure Test Question [Re: solarguy] #204558
01/25/09 11:22 PM
01/25/09 11:22 PM
several minutes
Re: Cooling System Pressure Test Question [Re: RapidRobert] #204559
01/25/09 11:41 PM
01/25/09 11:41 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
what happens to the bleed off?
Re: Cooling System Pressure Test Question [Re: solarguy] #204560
01/25/09 11:55 PM
01/25/09 11:55 PM
A very minute amt leaks either out to the ground, in to the combustion chamber & is burned or into the oil.
