Re: 383 build
[Re: fast68plymouth]
#2078658
05/23/16 03:58 AM
05/23/16 03:58 AM
Posts: 303 Portland, OR
Banzaiii67
Portland, OR
KB 162 Pistons have had two different designs.. I have an older version in my 383, the new 162's are rated for 8cc now.
Re: 383 build
[Re: Abodysforever]
#2078798
05/23/16 01:28 PM
05/23/16 01:28 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Like you would ever need valve pockets that deep(the new version) in any application where that was a suitable piston.
Just another example of someone not understanding what the market really needs.
Re: 383 build
#2078832
05/23/16 02:18 PM
05/23/16 02:18 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
That has pretty much been the business model of United machine regarding their Mopar pistons from day 1, in my opinion.
Re: 383 build
#2078833
05/23/16 02:21 PM
05/23/16 02:21 PM
Posts: 5,163 CT
GTX MATT
CT
To Russ's point, I don't know if correct height 1968/69 hp 383 pistons were ever available. I've never taken apart an original 68/69 hp 383....... Did those motors actually have positive deck height pistons as delivered from the factory? No, they were like .020 down
Re: 383 build
[Re: GTX MATT]
#2078834
05/23/16 02:23 PM
05/23/16 02:23 PM
JohnRR
U.S.S.A.
To Russ's point, I don't know if correct height 1968/69 hp 383 pistons were ever available. I've never taken apart an original 68/69 hp 383....... Did those motors actually have positive deck height pistons as delivered from the factory? No, they were like .020 down No , they are down .0025 -.003 at blueprint , positive .020 is the NHRA spec. Factory piston CH of the 68-69 383 is 1.932
Re: 383 build
[Re: Abodysforever]
#2078835
05/23/16 02:28 PM
05/23/16 02:28 PM
Posts: 5,163 CT
GTX MATT
CT
Well the one I took apart was no where near 0 deck, this was with '70 pistons. It was right around .020 down, maybe a little less, but it wasn't single digit or anywhere close. .020 down with a stock head gasket would be right around 9:1...
