Billet main cap question? #2044817
04/02/16 10:41 PM
04/02/16 10:41 PM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
Starting to put my engine together, and the thrust bearing will not even begin to go on the billet main cap. I checked them with a micrometer and the cap is .01 of an inch bigger the bearing. The bearing fits the stock cap just fine, so the problem must be the billet cap. Do I need to make a trip to the machine shop or could I use a flat file on the inside of the thrust surface of the bearing? T.I.A.
Re: Billet main cap question? [Re: Moparguy383] #2044824
04/02/16 10:44 PM
04/02/16 10:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
back to the machine shop. They should have set that when doing the honing
Re: Billet main cap question? [Re: Moparguy383] #2044869
04/02/16 11:21 PM
04/02/16 11:21 PM
Have the shop fix the main cap, do not file anything to fit on the mains tsk Filing rings to fit is fine, never mains twocents
Re: Billet main cap question? [Re: Cab_Burge] #2044936
04/03/16 12:31 AM
04/03/16 12:31 AM
Cumberland, MD
Cumberland, MD
That is what I thought, I just wanted to see what the consensus here was. I was trying to save myself the 250 mile round trip to the machine shop. It is not worth taking a chance destroying the engine just to save myself some time (and miles).
Thanks guys.
Reid. thumbs
Re: Billet main cap question? [Re: Moparguy383] #2044952
04/03/16 12:51 AM
04/03/16 12:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the 440Source billet main caps and all my bearings including the thrust bearing fit fine. Ron
Re: Billet main cap question? [Re: 383man] #2044958
04/03/16 12:56 AM
04/03/16 12:56 AM
Cumberland, MD
Cumberland, MD
383man,
These are also the 440 source caps. I have tried 2 different brands of bearings and they both fit the cap like this.
Reid.
Re: Billet main cap question? [Re: Moparguy383] #2044976
04/03/16 01:23 AM
04/03/16 01:23 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Call 440 Source and tell them.
Re: Billet main cap question? [Re: Moparguy383] #2044979
04/03/16 01:26 AM
04/03/16 01:26 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yes I agree, 440 source should replace the cap, it's not right.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Billet main cap question? [Re: ozymaxwedge] #2045041
04/03/16 04:02 AM
04/03/16 04:02 AM
Cumberland, MD
Cumberland, MD
I have already spoke with 440 source. I was told the cap should be machined to fit the bearing.
Re: Billet main cap question? [Re: Moparguy383] #2045045
04/03/16 04:18 AM
04/03/16 04:18 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Mate tell em to read their own web page
directly from the billet main cap description "and the thrust surface is already pre-cut into the #3 cap" says that for the normal and cross bolted ones
440 source should replace!
Re: Billet main cap question? [Re: Moparguy383] #2045108
04/03/16 09:36 AM
04/03/16 09:36 AM
Winston-Salem, NC
JackZ Offline
JackZ  Offline
Winston-Salem, NC
I bought two sets of billet steel main caps from 440 Source a couple years ago and on one set the #3 thrust bearing fit fine and on the other set it wouldn't go on (like yours). My conclusion was that their quality control needed/needs some work. With that being said, I took it to the local machine shop and they fixed it.
Re: Billet main cap question? [Re: Moparguy383] #2045325
04/03/16 02:16 PM
04/03/16 02:16 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The face is usually final fitted during the line bore - as it has to be a true 90 to the crank center line - take it back to the machine shop - they failed to do the final fit
Re: Billet main cap question? [Re: Moparguy383] #2045371
04/03/16 02:45 PM
04/03/16 02:45 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If he has started to assemble the motor, that means the caps have already been fit to the block........soooo, even if Source does send him a new cap, THAT cap will have to be fit and the line hone redone. That would be foolish. Machine the bearing register and call it a day. Don't step over a dollar to pick up a dime
Re: Billet main cap question? [Re: Monte_Smith] #2045492
04/03/16 04:19 PM
04/03/16 04:19 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
iagree
72 Plymouth Roadrunner 11.08@123.25
Re: Billet main cap question? [Re: Roughbird72] #2045637
04/03/16 07:53 PM
04/03/16 07:53 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
You might want to rethink your choice of machine shop, thrust surface should be checked and machined when doing the line bore. twocents
The only Carbs I care about are under the hood!
Re: Billet main cap question? [Re: Azzkikrcuda] #2045639
04/03/16 08:00 PM
04/03/16 08:00 PM
Cumberland, MD
Cumberland, MD
Thank you guys for all of the good information. I will be taking it to a machine shop. bow
