Clutch fan date code #2044891
04/02/16 11:50 PM
04/02/16 11:50 PM
Western Pa
farmboy70 Offline OP
Western Pa
While digging thru my parts I found this clutch fan.
What is the date code on this clutch.
Thank for the help.
Re: Clutch fan date code [Re: farmboy70] #2044897
04/02/16 11:56 PM
04/02/16 11:56 PM
Western Pa
Western Pa
Also would this be the correct power steering return hose markings for a 71 383?
Re: Clutch fan date code [Re: farmboy70] #2045179
04/03/16 11:29 AM
04/03/16 11:29 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
Thank for the help.
J =OCTOBER
7 = 7th day
A = 0 = 1970 in this case
Re: Clutch fan date code [Re: farmboy70] #2045181
04/03/16 11:30 AM
04/03/16 11:30 AM
DELAWARE
DELAWARE
3430 = 343rd day of 1970 = December 9th 1970
Re: Clutch fan date code [Re: farmboy70] #2045195
04/03/16 12:01 PM
04/03/16 12:01 PM
Western Pa
Western Pa
Hi
Thanks for the help. I see this is listed for most of the high performance engines in 1971.
Would this be considered correct for a 1971 SSP 383HP with four speed and AC?
Or would 3462107 be the one I need?
Thanks again.
Re: Clutch fan date code [Re: farmboy70] #2045263
04/03/16 01:29 PM
04/03/16 01:29 PM
Western Pa
Western Pa
Here is a picture of the inside.
Re: Clutch fan date code [Re: farmboy70] #2045654
04/03/16 08:30 PM
04/03/16 08:30 PM
DELAWARE
DELAWARE
Hi Dave
your welcome for the help
the clutch you picture is not correct for an a/c application
the #107 clutch you referenced is, it should have a thermostatic spring on the front of it
Tony
Re: Clutch fan date code [Re: farmboy70] #2046281
04/04/16 02:37 PM
04/04/16 02:37 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Hi
Thanks again.
112 is the 71 clutch for performance engines without AC
