Re: Master Cylinder Diameter Power Disc A Body
[Re: DoctorDiff]
#2045232
04/03/16 12:58 PM
04/03/16 12:58 PM
RapidRobert
'73-'76 A-bodies equipped with power disc brakes originally came with a 15/16" bore master cylinder. That'd be the .938" one he mentioned. Doc would there be an advantage (or disadvantage) to him going with the 1.038" one? I know on a manual non power setup a larger bore is less travel/more pedal effort/likely needed with 4 wheel discs to fill the calipers but how does that play out in a manual brake app? (going with a larger bore)
