Re: small block stroker build
[Re: cortsGTS]
#2044424
04/02/16 01:30 PM
04/02/16 01:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
looking to build and small block stroker motor should I do a 360 or 340 what is the difference? The main difference is the bore... a 340 base has a larger bore and will give a few more cubes... but 340 blocks are harder to find.. plenty of 360 blocks.. I like the big bore for after market heads with larger valves to help unshroud the valve ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: cortsGTS]
#2044594
04/02/16 05:58 PM
04/02/16 05:58 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Everybody always says 340 blocks are hard to find. No they aren't. You see them everywhere 500-700 dollars typically. Sometimes cheaper. As far as " using them up" who cares. Better than sitting and rusting on some garage floor being wasted. Life is too short. If they don't get used what good are they? For a typical 5,000 to 10, 000 dollar stroker build( or more) from start to finish, for the small difference in price between the 340 and a 360 block in the whole scheme of things, it's crazy to not use the bigger bore, more cubes advantage of the 340.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: cortsGTS]
#2046273
04/04/16 02:28 PM
04/04/16 02:28 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
My first and only preferance is the 360 magnum block. It is the strongest readily available block, most consistant bores even if they are a little thinner than an early 360 in the thick areas but that early 360 is more likely to have thin areas because of casting shift and 40 years of neglect. The easy to use and very cheap hydro-roller cam in the magnum trumps .040 bore size any day of the week. The block it self is very cheap, I have a couple I would sell for $100 ea. I usually get cores for $150. I don't have any hardness tester except my die grinder and it does not like grinding bore notches for a stroker in a magnum compared to an older block. Around here it is hard to find a 340 much less a 340 that is for sale. If I could get a decent 340 block for $500 I would snatch it up real fast to flip it to a restorer, hard to pass up a chance to double my money.
[Re: HotRodDave]
#2046315
04/04/16 03:33 PM
04/04/16 03:33 PM
Posts: 7,506 Az
Crizila
Az
I will start looking in to the Magnum 360 blocks for future builds. I have been building LA blocks ( earily and late E58 blocks ) simply because they were available to me at the time. Not sure on the validity regarding early blocks being thicker than later ones? Ran a 71 block out of a motor home and two 79 E58 blocks. All sonic tested real good. IMO, always best to start with a known "virgin" block ( never been apart before ) if you can. If the OP is not building real high end or odd ball, there are many dealers out there that sell "drop in" rotating assembly's based on the HP level you are lookin for. Makes it easy and eliminates first timer errors. Your machinist can really help you out in this area and often save you a lot of $.
Fastest 300
[Re: Crizila]
#2046339
04/04/16 03:58 PM
04/04/16 03:58 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
Either one, I like the earlier 68-71 blocks generally. Never built a Magnum block but I see no reason not to other than I heard you don't want to punch them more than .020-.030.
Presently I have both a 340 based 414 (4" stroke) and a 360 based 440 (4.25" Stroke).
340's can still be found but they are typically 3X what a decent 360 core will cost you, not really worth it unless you're doing a resto sleeper or numbers matching. The 360 has larger mains which is an advantage on the 4"+ strokes in terms of journal overlap, the downside is higher bearing speeds but generally a 4+ stroke you won't want (or really need) to turn it too high anyway.
[Re: cortsGTS]
#2046628
04/04/16 09:43 PM
04/04/16 09:43 PM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I used a 1990 360 LA block for my stroker build because it already had the bosses for the roller cam. I used stock Melling lifters and saved a ton.
1970 Duster 340 clone
[Re: Wedgeman]
#2046849
04/05/16 02:31 AM
04/05/16 02:31 AM
MR_P_BODY
My 416 made 590 on the dyno.. its just a throw together with stuff I had in the shop... W-2 heads with a .640 lift roller cam and 10.4 compression.. its in my Rampage so its a street/strip car.... thats a 340 block... the only parts I had to buy were the pistons because of the lower compression.. all my other pistons were in the 12+ range EDIT that was on 93 on the dyno... on the street I run 87 octane
