Page 4 of 5 1 2 3 4 5
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2043372
04/01/16 10:30 AM
04/01/16 10:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By 590 Challenger
I pay to use a website, if I were you I would just google the number on the alternator
I did but couldn't find what I was looking for. The reason I asked is that I've found plenty of alternators on 4 cylinder cars and I've found sources for the pulley. If the cars are the same physically as the early 90's 4 runner and trucks I'll buy one of them.
I'll figure it out.
Re: Toyota Alternator Upgrade [Re: justinp61] #2043411
04/01/16 12:08 PM
04/01/16 12:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
All the car alternators have rib belts with the exception and some early 80's rear drive cars. You should just find the correct one that fits the brackets that Andy makes and save some time messing spacers and bolts.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043414
04/01/16 12:11 PM
04/01/16 12:11 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Is that case size frt to back and does include the pulley. I measured the Toyota I have and got 4-7/8 frr to back and 5-3/4 with pulley.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043844
04/01/16 08:13 PM
04/01/16 08:13 PM
Parts unknown
590 Challenger Offline
Parts unknown
if you are asking me, I measured the diameter of the round part of the alternator body
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043863
04/01/16 08:40 PM
04/01/16 08:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
14433 is the denso dodge alternator at autozone with a V belt. Bout $100 and is made to fit a dodge.
14430 is the denso dodge alternator at autozone with rib belt. Bout $100 and is made to fit a dodge.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043894
04/01/16 09:29 PM
04/01/16 09:29 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am looking at using a 137 amp denso out of a Durango, can I get a V belt pulley for it? What vehicle is the Baby denso from? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Toyota Alternator Upgrade [Re: astjp2] #2043915
04/01/16 09:56 PM
04/01/16 09:56 PM
Parts unknown
Parts unknown
Kubota tractor, stock is 35 amp
Re: Toyota Alternator Upgrade [Re: fourgearsavoy] #2043920
04/01/16 10:03 PM
04/01/16 10:03 PM
AndyF Offline
AndyF  Offline
Gus beer
Seems like the easy solution to me too. I have the part numbers and the cross reference numbers on my website. Wiring instructions and pictures are also there.
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2043989
04/01/16 11:13 PM
04/01/16 11:13 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
My problem is the depth.I
Have a new Toyota alt but if I can fit the bigger one I may go that route on the dohn Deere one you sell.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044010
04/01/16 11:35 PM
04/01/16 11:35 PM
Parts unknown
Parts unknown
I had that issue when I had my motor plate, maybe you do too? When I was running an alternator off my motor plate I ran one of these. It's a GM alternator CS130D (D is for double internal fan, gving better cooling) they also work much better than the CS130 that many people use because it use larger bearings. Small bearings have been known to have been a issue on the CS130. I spaced out the long ear to pivot under the motor plate, keeping it out of the way. Stock 105 amp.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044271
04/02/16 10:15 AM
04/02/16 10:15 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have the AR kit for the denso 60 but was curious the depth on the higher amp denso
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044359
04/02/16 12:09 PM
04/02/16 12:09 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I am using a DENSO for a John Deere tractor.
120 Amps!!!
The case is slightly deeper over the car alternators, but they fit just fine!
Ryan
http://www.dbelectrical.com/p-5958-alter...CFZNhfgod3GYDDg
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2044380
04/02/16 12:32 PM
04/02/16 12:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think I have the one slightly bigger than the baby one. IIRC it's listed at 6.7 lbs 102mm one. It's for a Suzuki Samurai (remember those). IIRC, listed at 45 amps.
Looking at the powermaster website it's only slightly heavier than the baby-ultralight at 5.75 lbs
Mine does great at idle. It was a very noticeable improvement over my stock Chrysler alternator at idle with lights on. I have don't have a electrical fan or fuel pump. No radio either.
Re: Toyota Alternator Upgrade [Re: fourgearsavoy] #2044387
04/02/16 12:41 PM
04/02/16 12:41 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Gus beer
Pulleys are cheap and I can get a car alternator guaranteed to work for $20. Plus I like fabricating, it's part of hot rodding IMO. Otherwise I'd just be a parts changer.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044395
04/02/16 12:50 PM
04/02/16 12:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My 70 amp #14611 was only about $60 on ebay, the pulley can be bought from Summit Racing(made by Canton Racing iirc), or from AR-Engineering. Fits great on a motor plate.
Re: Toyota Alternator Upgrade [Re: redmist] #2044634
04/02/16 06:53 PM
04/02/16 06:53 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
120 Amps!!!
Ryan
dumb question time...so alternators meant for low RPM diesels will have no problems with high RPM motors??
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Toyota Alternator Upgrade [Re: jughed] #2045155
04/03/16 10:52 AM
04/03/16 10:52 AM
Parts unknown
Parts unknown
Diesel alternators as a rule of thumb always have better bearing than cars and are balanced the same way. Don't eve be afraid to use them. The durango alt the one guy was using has the same bearings, good choice
Re: Toyota Alternator Upgrade [Re: Scamp408] #2045162
04/03/16 11:08 AM
04/03/16 11:08 AM
Parts unknown
Parts unknown
The 120 amp JD and the 140 amp are the same size and use the exact same cases. I measured 5 3/8" but that is with the standard 8 groove pulley. Maybe a pic will help you decide??
Re: Toyota Alternator Upgrade [Re: Scamp408] #2045173
04/03/16 11:23 AM
04/03/16 11:23 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Thanks for the measurement. So it's like 7\16 deeper than the Toyota one.
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2045200
04/03/16 12:05 PM
04/03/16 12:05 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Is that 5 3/8" from the front of the case to the back?
