Re: A better intercooler for roots
[Re: Clanton]
#2043404
04/01/16 11:51 AM
04/01/16 11:51 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
These "after the screw" intercoolers seem to be gaining popularity.
Mopar to the bone!!!
[Re: FastmOp]
#2043610
04/01/16 04:00 PM
04/01/16 04:00 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I thought you already had something similar Mine is a 4" w core and the new will be 8" wide and rated at 2k HP not that I will make that.
[Re: Clanton]
#2043842
04/01/16 08:10 PM
04/01/16 08:10 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Does run a cool can (cold water) or engine coolant through it?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Clanton]
#2043918
04/01/16 10:02 PM
04/01/16 10:02 PM
Posts: 4,213 New York
polyspheric
New York
The discharge (bottom) side might look like the intake manifold, but the intake (top) side is a bad mis-match to the actual flow pattern leaving any helixed blower. A lot of the coolant isn't doing anything.
Boffin Emeritus
[Re: polyspheric]
#2043959
04/01/16 10:48 PM
04/01/16 10:48 PM
Clanton
northern,Ohio,USA
The discharge (bottom) side might look like the intake manifold, but the intake (top) side is a bad mis-match to the actual flow pattern leaving any helixed blower. A lot of the coolant isn't doing anything. The core changes the path of the flow I agree.
[Re: astjp2]
#2043961
04/01/16 10:51 PM
04/01/16 10:51 PM
Clanton
northern,Ohio,USA
Does run a cool can (cold water) or engine coolant through it? I have a water cell for the intercooler.
[Re: Dragula]
#2046146
04/04/16 12:02 PM
04/04/16 12:02 PM
Clanton
northern,Ohio,USA
I dont like it lower.Rons cooler supports 2,000 hp.The whipple core looks short where Rons is 4" thick proven cores.I do not have to change anything for me to use Rons cooler.
[Re: hemi-itis]
#2046148
04/04/16 12:05 PM
04/04/16 12:05 PM
Clanton
northern,Ohio,USA
Will that lower IATs more than water/meth???? Not even in the same league so yes it would be more effective.
