Indy SB single plane flange thickness??? #2042995
03/31/16 09:40 PM
03/31/16 09:40 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Trying to buy a used Indy SB intake that is uncut. Wondering if anybody has a brand new one that they could measure for me and get back to me as I have found one that has been measured for me but not sure what the spec should be....I doubt if I called Indy they would be nice enough to do it for me, so I'm wondering if anyone here can help
Thanks!
Re: Indy SB single plane flange thickness??? [Re: mshred] #2045646
04/03/16 08:16 PM
04/03/16 08:16 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Nobody has an out of the box stock manifold they can measure for me? I found a used intake but need a measurement to compare to.
Re: Indy SB single plane flange thickness??? [Re: mshred] #2045715
04/03/16 09:54 PM
04/03/16 09:54 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Which flange?
Re: Indy SB single plane flange thickness??? [Re: mshred] #2045718
04/03/16 09:57 PM
04/03/16 09:57 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
The port sides
Re: Indy SB single plane flange thickness??? [Re: mshred] #2045739
04/03/16 10:31 PM
04/03/16 10:31 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Mine is mounted I thought you needed carb side
Re: Indy SB single plane flange thickness??? [Re: mshred] #2047488
04/05/16 11:05 PM
04/05/16 11:05 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Gonna give this one last bump...has to be someone out there with a brand new intake that can measure for me....id call Indy but ever since Josh left I'd rather not-ordering intake gaskets was like pulling teeth without anaesthetics
Help?
Re: Indy SB single plane flange thickness??? [Re: mshred] #2047593
04/06/16 12:51 AM
04/06/16 12:51 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have a new Indy W2 manifold in the garage. I measured the flange thickness between the runners. Its about .415 at the top and ends up about 580 as far in as my calipers will reach. It also appears to be just an "OK" casting quality so I imagine there is some variance between pieces.
If you buy one and its been milled to much you can get thicker gaskets if you need them.
68 Barracuda Formula S 340
Re: Indy SB single plane flange thickness??? [Re: Bad340fish] #2047754
04/06/16 10:39 AM
04/06/16 10:39 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Cometic can make whatever thickness you need, and now the bolt spacing and placement is correct.
