Dakota 440 swap front spring swap? #2042075
03/30/16 05:01 PM
03/30/16 05:01 PM
Jacksonville, AR
dmckeehan Offline OP
Jacksonville, AR
Gathering info on swapping a 440 into my recently purchased 1992 Dakota. I'm up on the engine mounts and headers and such, just curious what is needed on the front coils. Will the stock coils work, or need to upgrade? what parts swap in? thanks for the help guys
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205
2002 3500 extended cab, 4x4, Cummins and 6 speed
1997 Ram 2500 5.9 with 35 Boggers - Mud Racer
1993 Dakota 4x4, Dana 60's front and rear - work in progress
1992 Dakota 2wd short bed, awaiting 440 swap
Re: Dakota 440 swap front spring swap? [Re: dmckeehan] #2042088
03/30/16 05:19 PM
03/30/16 05:19 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Re: Dakota 440 swap front spring swap? [Re: dmckeehan] #2042197
03/30/16 07:55 PM
03/30/16 07:55 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sounds like you don't have to do much, maybe a set of V8 coil springs and call it done
Re: Dakota 440 swap front spring swap? [Re: dmckeehan] #2042216
03/30/16 08:29 PM
03/30/16 08:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Maybe if it is drag only you could use the 4cyl springs for weight transfer or V8 springs if cornering is more important.
Re: Dakota 440 swap front spring swap? [Re: dmckeehan] #2042519
03/31/16 07:55 AM
03/31/16 07:55 AM
Jacksonville, AR
Jacksonville, AR
Thanks guys, it's going to be an evolution, street truck in the beginning with occasional strip duty. As it evolves, it will become more strip oriented
Re: Dakota 440 swap front spring swap? [Re: dmckeehan] #2042721
03/31/16 02:38 PM
03/31/16 02:38 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
Aluminum heads and intake didn't squit 4/cylinder springs on bit
Re: Dakota 440 swap front spring swap? [Re: dmckeehan] #2043520
04/01/16 02:12 PM
04/01/16 02:12 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
I think El Polako has some tubular control arms for coilovers coming up for the early Daks;
http://i2.wp.com/www.industrialchassisin...18-07.56.15.jpg
Greg
Re: Dakota 440 swap front spring swap? [Re: Greg55_99] #2043951
04/01/16 10:42 PM
04/01/16 10:42 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Greg
I hope this is sign that Steve is getting back into the Dakota front clips again.
He had some awesome stuff several years ago, then pretty much quit making stuff. Gene
Re: Dakota 440 swap front spring swap? [Re: poorboy] #2044383
04/02/16 12:38 PM
04/02/16 12:38 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
My v6 club cab 1998 Dakota weighed 4000 lbs
I swapped in a 383 stroked to 438 with aluminum heads, intake, water pump/housing and a TKO-600. Truck weighed 4200 lbs. or, the same as a V8 club cab Dakota.
The big block doesn't add much weight when you use aluminum parts.
Strip duty? Use the lightest springs you can find. Otherwise, swap in some stock v8 springs, cut 1/4-1/2 of a coil off which will both lower it and stiffen the overall spring a little bit.
**Photobucket sucks**
Re: Dakota 440 swap front spring swap? [Re: dmckeehan] #2045765
04/03/16 10:58 PM
04/03/16 10:58 PM
Jacksonville, AR
Jacksonville, AR
thanks!
