How much valve lash on a solid cam? #2042583
03/31/16 10:56 AM
03/31/16 10:56 AM
midwest
superchuck Offline OP
On thin ice
On thin ice
midwest
I using a MP solid cam with edelbrock aluminum heads. What should I set my lash too?
Re: How much valve lash on a solid cam? [Re: superchuck] #2042638
03/31/16 12:21 PM
03/31/16 12:21 PM
Idaho
LaRoy Engines Offline
Idaho
If you are using any of the MP solid flat tappet cams with .620" lift or less, start at .022" IN/.026" EX (cold) lash and .028"/.032" (hot) lash. The higher lift flat tappets would be (cold) .018/.022 and (hot) lash would be .024/.028.
Re: How much valve lash on a solid cam? [Re: superchuck] #2042660
03/31/16 12:56 PM
03/31/16 12:56 PM
midwest
On thin ice
On thin ice
midwest
Thanks! its a .557
Re: How much valve lash on a solid cam? [Re: superchuck] #2042744
03/31/16 03:22 PM
03/31/16 03:22 PM
Washington
madscientist Offline
Washington
I set them at .020 cold and check them hot. .022 hot is PLENTY of lash. Any more than that is just bashing parts.
Re: How much valve lash on a solid cam? [Re: superchuck] #2042880
03/31/16 06:42 PM
03/31/16 06:42 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I used to set my .590 with RPM heads at .020 cold as well.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: How much valve lash on a solid cam? [Re: LaRoy Engines] #2043198
04/01/16 12:09 AM
04/01/16 12:09 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I believe that this is also what Ma Mopar recommended as well.
Re: How much valve lash on a solid cam? [Re: superchuck] #2043238
04/01/16 12:55 AM
04/01/16 12:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a .018 on all of my MP cams.. both intake and
exhaust.. have been for 15 years now.. thats both
on alum and iron heads.. never burnt a valve yet..
I hated how sloppy they sounded with .028 lash...
plus at the tighter lash it has always made more power
on my junk
EDIT
All my cams are rollers
wave
Re: How much valve lash on a solid cam? [Re: superchuck] #2043311
04/01/16 05:32 AM
04/01/16 05:32 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I agree, .018 -.022 cold
1963 Plymouth Max Wedge
1971 Barracuda
