Re: Looking for detailed pictures of max wedge cars
[Re: SCATPK]
#2017183
02/22/16 04:37 AM
02/22/16 04:37 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Wow thats looking great ! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Thanks for posting them pics and post as many as you like when you want too as I will enjoy looking at them. Ron
[Re: SCATPK]
#2040637
03/28/16 08:23 PM
03/28/16 08:23 PM
Posts: 1,954 Illinois
SGTFURY62
Illinois
Other than the powertrain and the hood bracing notched for the cross ram air cleaners, it is standard 4 door fare. A four door Maxie!???
[Re: SCATPK]
#2041718
03/30/16 04:36 AM
03/30/16 04:36 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
Yes, a factory built 4 door, 3spd, hc426 car. Thinking of bringing this car down to Spring Fling 30? Restored or In-Progress.
[Re: autoxcuda]
#2041759
03/30/16 10:28 AM
03/30/16 10:28 AM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Is this the car from WA state
Abe Lincoln
[Re: SCATPK]
#2042227
03/30/16 08:41 PM
03/30/16 08:41 PM
Posts: 3,104 Michigan
A727Tflite
I don't see it mentioned here but in the past the best paint I could find (close to original color when compared to parts painted originally in the 60's) was PlastiKote 226. I sold it back in the day and used lots of it on restorations and race engines without issue. And it covered in one coat - two max. The Direct Connection paint back in the 70's and 80's was garbage - it ran if you got any decent fuel on it. PlastiKote was the best back then - not sure today. Check it out. Another option back then was Rustoleum "Safety Orange" in brush on or in a rattle can. Also check out PlastiKote HP-15 High Temp Paint.
[Re: SCATPK]
#2042754
03/31/16 03:39 PM
03/31/16 03:39 PM
A727Tflite
Yes, because the 3447 carbs had inlets in different locations than the 3705. 1962 and 1963 had the larger routing of the lines while the 1964 had the lines running between the carbs towards the front of the engine. Bob Matthews brown car is correct for the 1964 model years. The black and white photo above is correct for 1962 and 1963.
