Re: A12 11" Drum brakes??
[Re: cdp]
#204221
01/25/09 05:22 PM
01/25/09 05:22 PM
No one will know the difference unless the brake drum is off.
The self adjusters work by adjusting the brakes from backing up and stepping on the brakes. Normal driving will keep them adjusted just fine with the self adjusters. If you don't have them then you need to take the rubber plug at the bottom of the backing plate out and turn the adjuster wheel with a screw driver about every 5000 miles or so.
[Re: cdp]
#204223
01/25/09 06:08 PM
01/25/09 06:08 PM
It doesn't matter because you have no need for the plug with self adjusters.
[Re: JohnRR]
#204225
01/25/09 09:12 PM
01/25/09 09:12 PM
Posts: 3,691 MO
cdp
MO
The main reason for not using the old adjusters and the rest of the od hardware is basically because everything is new or restored.
The backing plates are powdercoated, new shoes, springs, hoses, wheel cylinders, etc., etc....
I just didn't realize the the self-adjusting and the non-self adjusting were 2 different designs. If I would have paid more attention in the beginning, i would have ordered the correct replacement. I just figured that since I had all the hardware in the kit, I might as well go ahead and convert.
[Re: cdp]
#204229
01/26/09 11:04 AM
01/26/09 11:04 AM
Posts: 851 Avondale AZ
Prodart440
Avondale AZ
I did the same thing on my 68 roadrunner. Everything works just fine, but to fine tune the brakes from the back, the holes don't line up with the self adjusters.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
