Speedometer Gear Question #2041421
03/29/16 09:13 PM
03/29/16 09:13 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Can anyone tell me if a 52068159 37 tooth speedo gear will fit a '68 727 trans? I found a few online sources that says yes and some that say no because it is meant for a screw on speed sensor for later transmissions. Which one is it- yes or no??? Thanks!
Re: Speedometer Gear Question [Re: mopowers] #2041506
03/29/16 10:55 PM
03/29/16 10:55 PM
I'd post how long is the shank. I'm thinking there are only several varieties of em so with that dimention I think the guys here can ID it right away
Re: Speedometer Gear Question [Re: mopowers] #2041523
03/29/16 11:11 PM
03/29/16 11:11 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yes, that is an early long shank speedo gear. It will fit your 68 tranny no problem.
Re: Speedometer Gear Question [Re: mopowers] #2041599
03/30/16 12:28 AM
03/30/16 12:28 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Here's a couple. Would these work??? http://www.morris4x4center.com/37-tooth-long-speedometer-gear-white-52068159.html
http://www.ebay.com/itm/Dodge-Jeep-37-Tooth-Speedometer-Gear-Long-Shaft-with-Oring-and-stem-seal-/161722538260?hash=item25a76a1914:g:DD8AAOxy3HJTHfWC&vxp=mtr
BTW- Happy Birthday RapidRobert. Hope it's a good one!
Re: Speedometer Gear Question [Re: Pacnorthcuda] #2041600
03/30/16 12:29 AM
03/30/16 12:29 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Awesome! Thanks man
Re: Speedometer Gear Question [Re: mopowers] #2041629
03/30/16 12:59 AM
03/30/16 12:59 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The shaft recess in the reproduction gears aren't deep enough to accept the manual speedo cable, that is why they are listed for the electronic sensor and not the earlier cable driven applications. The company that reproduced them didn't verify fitment before making thousands of them.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Speedometer Gear Question [Re: 64dodge572] #2041651
03/30/16 01:30 AM
03/30/16 01:30 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
That makes sense. How far off are they? Would trimming the speedo cable make it usable? How bout swapping shafts from an old one? I've heard its just a slight press fit. Not sure if it's true though.
Re: Speedometer Gear Question [Re: mopowers] #2041662
03/30/16 01:48 AM
03/30/16 01:48 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Gears are molded on a knurled shaft, not removable. Good luck trimming the cable without fraying it.
Re: Speedometer Gear Question [Re: 64dodge572] #2041664
03/30/16 01:55 AM
03/30/16 01:55 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
That's a bummer. Thanks for the info. I appreciate it.
Re: Speedometer Gear Question [Re: 64dodge572] #2042038
03/30/16 04:05 PM
03/30/16 04:05 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Damn, you're right. I called on a new reproduction one and the recess for the cable is only 5/8" as opposed to 1-1/8" in my old one. Does that mean I'm reduced to looking for a used 37 tooth gear? Or does someone reproduce an accurate original that I can use a cable with?
Re: Speedometer Gear Question [Re: mopowers] #2042082
03/30/16 05:10 PM
03/30/16 05:10 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Plenty of them on Ebay.
Re: Speedometer Gear Question [Re: stumpy] #2042134
03/30/16 06:05 PM
03/30/16 06:05 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
The only 37 tooth gear I've found are reproductions.
Re: Speedometer Gear Question [Re: mopowers] #2042180
03/30/16 07:34 PM
03/30/16 07:34 PM
Grand Prairie,Texas
Grand Prairie,Texas
I just did a search for mopar 37 tooth speedo gears on ebay and a bunch of sellers of used gears showed up.
Re: Speedometer Gear Question [Re: stumpy] #2042395
03/31/16 12:13 AM
03/31/16 12:13 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
None of them have 37 tooth gears. They just put all the numbers in the title of their ad so they show up. Its BS. I guess I'll just have to be on the lookout.
Re: Speedometer Gear Question [Re: mopowers] #2042420
03/31/16 01:00 AM
03/31/16 01:00 AM
Grand Prairie,Texas
Grand Prairie,Texas
I have a 52068159 that I an stick a paper clip an inch and an 1/8th into. Can you do that with the repo type or do they only go 5/8". It's white with a 59 in a square.
Re: Speedometer Gear Question [Re: mopowers] #2042426
03/31/16 01:08 AM
03/31/16 01:08 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
The guys selling the repro 52068159 gears said his only have a 5/8" recess. Do you know when yours was made? I've been told the newer reproductions have shallower recesses which interfere with cable drive speedos. Thanks for your help btw. I appreciate it. How much do you want for yours?? lol
Re: Speedometer Gear Question [Re: mopowers] #2042430
03/31/16 01:13 AM
03/31/16 01:13 AM
Grand Prairie,Texas
Grand Prairie,Texas
In don't know when it was made but it came from a stock trans. If we were sure it would fit I'd make to a deal. But I don't want to say until we know it's right.That's why I asked about the depth. Some one should know for sure. How do you tell a repo from an original?
Re: Speedometer Gear Question [Re: mopowers] #2042846
03/31/16 05:56 PM
03/31/16 05:56 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Just an FYI for folks. I swung by the local speedometer shop. It's a small mom and pop business and have been there forever. They actually had a short shaft 37 tooth gear in stock. The old guy behind the counter pressed the short shaft off and tapped a long one for me. So yes, it can be done. You just have to support the plastic gear very well and take your time. Thanks for all the input guys.
Re: Speedometer Gear Question [Re: mopowers] #2042851
03/31/16 06:01 PM
03/31/16 06:01 PM
Grand Prairie,Texas
Grand Prairie,Texas
up Old timers rule.
Re: Speedometer Gear Question [Re: mopowers] #2042863
03/31/16 06:18 PM
03/31/16 06:18 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I agree. He was one of the nicest old guys I've ever met. Very eager to help me and get what I needed. It's nice knowing there are small specialty shops like his still around.
