Engine bolts #2041339
03/29/16 07:01 PM
03/29/16 07:01 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...For a rebuild,which bolts would you definitely not re-use?
...head bolts...rod bolts..main cap bolts???
Re: Engine bolts [Re: can.al] #2041347
03/29/16 07:11 PM
03/29/16 07:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If it's a stock motor you should be fine with the factory hardware. If it's something that is going to be driven with enthusiasm then you'll need to swap head, rod, and main bolts.
It's cheap insurance on any build.
- Stu Harmon
Re: Engine bolts [Re: can.al] #2041364
03/29/16 07:47 PM
03/29/16 07:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Heads and mains should be fine. I like the idea of replacing rod bolts BUT that has to be done before and only if you're resizing the big end.
Re: Engine bolts [Re: Stanton] #2041366
03/29/16 07:54 PM
03/29/16 07:54 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Correct. Again, if you plan on driving with enthusiasm it is a necessary evil.
- Stu Harmon
Re: Engine bolts [Re: can.al] #2041451
03/29/16 10:04 PM
03/29/16 10:04 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Rod bolts! They are the most stressed part in the engine. Big end of rods are usually re-sized after replacing the rod bolts.
All the rest of the bolts can be reused if in good condition. I have had issues with the stock 1/4 bolts breaking (valve covers, and other places they might be used?) That's likely from me over tightening them.
Re: Engine bolts [Re: can.al] #2041456
03/29/16 10:12 PM
03/29/16 10:12 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Factory bolts...
Heat-cycled, stretched, and stressed who knows how many times...
Bolts...
New bolts...
Better to have them, than wish you did...
Re: Engine bolts [Re: 451Mopar] #2041602
03/30/16 12:29 AM
03/30/16 12:29 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Originally Posted By 451Mopar
[snip]... I have had issues with the stock 1/4 bolts breaking (valve covers, and other places they might be used?) That's likely from me over tightening them.
...and because of the weird 7-degree angle big-block valve covers screws are installed at!
Rick
Re: Engine bolts [Re: can.al] #2041626
03/30/16 12:58 AM
03/30/16 12:58 AM
If your going to do a stock type build with rings, bearings, valve job and maybe a little bigger cam I would take the rods with the stock bolts torque to 45 ft lbs with oil to someone who has a good dial bore gauge and have them check the roundness of the rods(all 8) big end bore. If they are all round I would, and have many times, reuse those rods and put the money for the new rod bolts and resizing the big end of the rods to a better use thumbs twocents If you don't know the history of the motor and you have ANY doubts about reusing the rods or bolts swap them out up
Re: Engine bolts [Re: can.al] #2042762
03/31/16 03:49 PM
03/31/16 03:49 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
.....grade 8 bolts are very hard.I'm thinking they would break if they were to fail?
who have seen a broken or stretched main cap or head bolt?
Re: Engine bolts [Re: can.al] #2042787
03/31/16 04:33 PM
03/31/16 04:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I've always reused main cap bolts.
Head bolts usually get replaced, but not always. My brother has assembled many engines for himself and friends and says used head bolts will produce a rubbery feel during the final torque down. Doubt they would ever break, but they may not hold tight enough which could mean the head gaskets could fail. Best to replace if in doubt.
Rod bolts? I always get new ARP ones.
