Re: Toyota Alternator Upgrade
[Re: 590 Challenger]
#2043372
04/01/16 10:30 AM
04/01/16 10:30 AM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
I pay to use a website, if I were you I would just google the number on the alternator I did but couldn't find what I was looking for. The reason I asked is that I've found plenty of alternators on 4 cylinder cars and I've found sources for the pulley. If the cars are the same physically as the early 90's 4 runner and trucks I'll buy one of them. I'll figure it out.
[Re: justinp61]
#2043411
04/01/16 12:08 PM
04/01/16 12:08 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
All the car alternators have rib belts with the exception and some early 80's rear drive cars. You should just find the correct one that fits the brackets that Andy makes and save some time messing spacers and bolts. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Scamp408]
#2043414
04/01/16 12:11 PM
04/01/16 12:11 PM
Posts: 2,709 NJ central
Scamp408
NJ central
Is that case size frt to back and does include the pulley. I measured the Toyota I have and got 4-7/8 frr to back and 5-3/4 with pulley.
[Re: Scamp408]
#2043844
04/01/16 08:13 PM
04/01/16 08:13 PM
Posts: 493 Parts unknown
590 Challenger
Parts unknown
Is that case size frt to back and does include the pulley. I measured the Toyota I have and got 4-7/8 frr to back and 5-3/4 with pulley. if you are asking me, I measured the diameter of the round part of the alternator body
[Re: Scamp408]
#2043863
04/01/16 08:40 PM
04/01/16 08:40 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
14433 is the denso dodge alternator at autozone with a V belt. Bout $100 and is made to fit a dodge.
14430 is the denso dodge alternator at autozone with rib belt. Bout $100 and is made to fit a dodge.
[Re: Scamp408]
#2043894
04/01/16 09:29 PM
04/01/16 09:29 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am looking at using a 137 amp denso out of a Durango, can I get a V belt pulley for it? What vehicle is the Baby denso from? Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2043915
04/01/16 09:56 PM
04/01/16 09:56 PM
590 Challenger
Parts unknown
I am looking at using a 137 amp denso out of a Durango, can I get a V belt pulley for it? What vehicle is the Baby denso from? Tim Kubota tractor, stock is 35 amp
[Re: fourgearsavoy]
#2043920
04/01/16 10:03 PM
04/01/16 10:03 PM
Posts: 31,069 Oregon
AndyF
All the car alternators have rib belts with the exception and some early 80's rear drive cars. You should just find the correct one that fits the brackets that Andy makes and save some time messing spacers and bolts. Gus Seems like the easy solution to me too. I have the part numbers and the cross reference numbers on my website. Wiring instructions and pictures are also there.
#2043989
04/01/16 11:13 PM
04/01/16 11:13 PM
Scamp408
NJ central
Is that case size frt to back and does include the pulley. I measured the Toyota I have and got 4-7/8 frr to back and 5-3/4 with pulley. if you are asking me, I measured the diameter of the round part of the alternator body My problem is the depth.I Have a new Toyota alt but if I can fit the bigger one I may go that route on the dohn Deere one you sell.
[Re: Scamp408]
#2044010
04/01/16 11:35 PM
04/01/16 11:35 PM
590 Challenger
Parts unknown
Is that case size frt to back and does include the pulley. I measured the Toyota I have and got 4-7/8 frr to back and 5-3/4 with pulley. if you are asking me, I measured the diameter of the round part of the alternator body My problem is the depth.I Have a new Toyota alt but if I can fit the bigger one I may go that route on the dohn Deere one you sell. I had that issue when I had my motor plate, maybe you do too? When I was running an alternator off my motor plate I ran one of these. It's a GM alternator CS130D (D is for double internal fan, gving better cooling) they also work much better than the CS130 that many people use because it use larger bearings. Small bearings have been known to have been a issue on the CS130. I spaced out the long ear to pivot under the motor plate, keeping it out of the way. Stock 105 amp.
#2044380
04/02/16 12:32 PM
04/02/16 12:32 PM
Posts: 27,475 So Cal
autoxcuda
So Cal
I am looking at using a 137 amp denso out of a Durango, can I get a V belt pulley for it? What vehicle is the Baby denso from? Tim Kubota tractor, stock is 35 amp I think I have the one slightly bigger than the baby one. IIRC it's listed at 6.7 lbs 102mm one. It's for a Suzuki Samurai (remember those). IIRC, listed at 45 amps. Looking at the powermaster website it's only slightly heavier than the baby-ultralight at 5.75 lbs Mine does great at idle. It was a very noticeable improvement over my stock Chrysler alternator at idle with lights on. I have don't have a electrical fan or fuel pump. No radio either.
[Re: fourgearsavoy]
#2044387
04/02/16 12:41 PM
04/02/16 12:41 PM
justinp61
W. Kentucky
All the car alternators have rib belts with the exception and some early 80's rear drive cars. You should just find the correct one that fits the brackets that Andy makes and save some time messing spacers and bolts.Gus Pulleys are cheap and I can get a car alternator guaranteed to work for $20. Plus I like fabricating, it's part of hot rodding IMO. Otherwise I'd just be a parts changer.
[Re: Scamp408]
#2044395
04/02/16 12:50 PM
04/02/16 12:50 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
My 70 amp #14611 was only about $60 on ebay, the pulley can be bought from Summit Racing(made by Canton Racing iirc), or from AR-Engineering. Fits great on a motor plate.
