Re: 413 Truck Block Date Identification?? [Re: John_Kunkel] #2043735
04/01/16 06:21 PM
04/01/16 06:21 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Originally Posted By John_Kunkel
The water pump setup in that pic isn't correct, the industrial 413 has the water pump housing mounted high on the heads.
Exactly. So the water pump housing is not correct for those heads and the engine could not have run with what I see on it. Not only would the pulley's not line up but, as one can see, the head water passages are wide open to the world.
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2043855
04/01/16 08:32 PM
04/01/16 08:32 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Correct, hence the open water ports at the front of the heads and the block off plates on the back of the heads. Without the correct water pump housing, I believe you would have to change the heads in order to use the block??
In researching information on this engine, I read the following......
"The water pump housing directs coolant straight from the radiator directly into the front of the heads. The heads have small sodium filled valves that can handle full throttle temperatures for long periods up long grades. The exhaust manifolds are unique to those heads."
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2044047
04/02/16 12:08 AM
04/02/16 12:08 AM
ND
dodgedon Offline
dodgedon  Offline
ND
The picture's shown above are just like our 66 413 truck engine. As stated the water pump is high on the engine. The orange pump in your picture is typical car/pickup style and would not have run that way. I would say the distributor was also "Added" to this deal. These engines usually have a much larger distributor and governor setup. The exhaust manifolds are the same as our truck (CT800) and are unique to these heads. I would add one more thing... As stated the cranks are very heavy duty and I believe the rear flange may hang out the rear farther than typical RB car type cranks.
These 413 engines will handle "full throttle loaded work" all day long. But they only run 2500-3000 RPM max.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 413 Truck Block Date Identification?? [Re: dodgedon] #2046210
04/04/16 01:05 PM
04/04/16 01:05 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
On the subject of 413 motor home engines, can anyone decipher my pad? Mine reads:
G T 413 V 2 3 (the V might be an upside down A)
Greg
Re: 413 Truck Block Date Identification?? [Re: Greg55_99] #2046395
04/04/16 05:02 PM
04/04/16 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
G T 413 V 2 3
G= 1971
T= Trenton engine plant
413= Displacement
V= Upside down A
2 3= Build date February 3
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2046430
04/04/16 05:55 PM
04/04/16 05:55 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Thanks. Can't figure out that upside down "A"...
Greg
