Where can I buy Small Block race heads?
#204015
01/25/09 02:01 PM
01/25/09 02:01 PM
I have Norris stainless steel roller rockers on my small block race motor with W-2 heads. The roller bearings on 2 of the rocker arms wore a groove into the rocker tip. Turns out Norris is out of business. I can't buy a set of off the shelf replacement rockers because the shaft mounts have been altered. My engine builder suggests that I send the heads to Jessel and have them make me a custom set of stainless rockers. Cost will be $2,000. I'm thinking, maybe I should spend the money on a new set of heads. I've been having trouble finding small block race heads on-line. It seems all the Mopar (Koffels, Indy, etc) sites specialize in Big block heads. Does anybody know where I can get a good set of SB (drag) race heads?
Re: Where can I buy Small Block race heads?
[Re: B1Fish540]
#204018
01/25/09 04:05 PM
01/25/09 04:05 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Are you just looking for a replacement to the W2? If so you can still buy W2 stuff. Or as mentioned there are a lot of other heads out there. Edelbrocks (Either Standard, or Magnum style), B1-BA heads, Indy Brocks, Mopar Commando, Mopar W2, Indy 360-2, Indy 360-1, W5's (if you can find them), or more exotic W7/W8/W9 stuff is availible too. RyanJ is the small block guru, he can point you in the right direction, and is a great guy to work with. www.shadydellspeedshop.com
[Re: dizuster]
#204019
01/25/09 04:55 PM
01/25/09 04:55 PM
I'm looking for replacement W-2 heads.
[Re: 72demon416]
#204023
01/26/09 09:30 PM
01/26/09 09:30 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Member S/ST 3040 had a set of new W2's for sale in the classifieds recently- not sure if it's what your needing exactly-just a heads up.
They are P5007708AB W-2 heads. 15º valve angle, 47 cc chambers, for a 48º block. Already factory machined for T&D or Jesel rockers.
I just sold my only 2 sets of Norris rockers.
