Page 2 of 3 1 2 3
Re: Wheels up launch, adjustment question [Re: WheelsUp73] #2040006
03/27/16 09:21 PM
03/27/16 09:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Originally Posted By WheelsUp73
Originally Posted By Dave Hall
Try a quarter turn of pre-load, right side Don.
First off get a set of scales and scale the car before you touch anything. More than likely you are light on the right rear side of the car causing the slight body roll and driving right.Once the rear is set properly it will leave straight and pick up both wheels evenly. You Dont need an anti rollbar.
just about everyone would benefit from an anti-roll
Re: Wheels up launch, adjustment question [Re: Quicktree] #2040022
03/27/16 09:42 PM
03/27/16 09:42 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
I dont agree. Set up the chassis right and it will not be needed.
Re: Wheels up launch, adjustment question [Re: WheelsUp73] #2040023
03/27/16 09:46 PM
03/27/16 09:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you dont put them on 4 links either
wave
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040035
03/27/16 10:07 PM
03/27/16 10:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Go ahead and add some pre load.. thats a
quick and easy try.. it will help it from
turning right.. but IMO it wont correct the
roll onto the RR tire.. but try the pre load
and get back later
wave
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040096
03/27/16 11:20 PM
03/27/16 11:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
having scaled my car and noting how much slight adjustments change things I'm surprised at the "throw a 1/4 turn at it" recommendation.... and I'm by no means a seasoned pro at this stuff. Maybe this is coming from folks a lot more comfortable at these "adjustments" than I was.
Re: Wheels up launch, adjustment question [Re: WheelsUp73] #2040102
03/27/16 11:23 PM
03/27/16 11:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I used to think that when they were first starting to show up and were considered exotic. Now, I wouldn't put one together without it. Another tuning tool in the toolbox.
And I agree on the scales. If you don't know where the weight is, you're guessing with your eyes closed. Bad springs and broken parts will show up on the scales. At a minimum, use the scales to verify that stuff is OK and baseline the car. Then go to the track and it will tell you what it wants.
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040130
03/28/16 12:02 AM
03/28/16 12:02 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
This is recordings of the car before I did the coil over strut conversion.. Havent had the opportunity to scale it afterwards, but here is what I got..
LF 773
RF 843
LR 687
RR 683
TOTAL 2986
With Driver and fuel
LF 853
RF 883
LR 814
RR 684
TOTAL 3234
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040138
03/28/16 12:10 AM
03/28/16 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
LF 773
RF 843
LR 687
RR 683
TOTAL 2986
LF 853
RF 883
LR 814
RR 684
TOTAL 3234
Did you change the back at at.. did you measure
the front(from the fender opening before and after)
you changed things
wave
Re: Wheels up launch, adjustment question [Re: WheelsUp73] #2040157
03/28/16 12:25 AM
03/28/16 12:25 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
First off get a set of scales and scale the car before you touch anything. More than likely you are light on the right rear side of the car causing the slight body roll and driving right.Once the rear is set properly it will leave straight and pick up both wheels evenly. You don't need an anti rollbar.
I agree with Steve, my Challenger is ladder as well and when scaled and set up correctly leaves even, shouldn't need a anti-roll bar Don. One other thing is verify all the lock nuts on your ladders are tight and not allowing any twisting movement within themselves.
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040163
03/28/16 12:31 AM
03/28/16 12:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
LF 773
RF 843
LR 687
RR 683
TOTAL 2986
LF 853
RF 883
LR 814
RR 684
TOTAL 3234
I've tuned by adding preload/shock changes and using a scale. The final test may always need adjustment from the scale readings. If the weight is still in the range shown no wonder it goes right. The left rear is 130 lbs heavier than the right. It would benefit moving weight to the right. If that's not possible in my opinion it needs more than a 1/4 turn. I usually count the flats on the adjuster. My bet is it'll take 3-5. Start at 2 and work your way up. The ladder bar in itself works as an anti-roll bar unlike a 4 link. If there is very little flex it won't need one. All depends on how stiff the chassis, housing, and bars are. Mine is stock frame rail with no ARB with 3-4 flats of preload (every car is different). Dead level,1.25-1.27 foot brake. This picture tire is 13.5 psi
Doug
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040173
03/28/16 12:40 AM
03/28/16 12:40 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
Don BTW what does that car weigh? I run 8# and told by a few self believed chassis guru's over the years I was hitting my tires to hard and should add air like 9# which wreaked havoc with my car going right or left, I rotate my tires side to side every 25 passes to save the sidewalls and typically get 300 passes out of a set.
Re: Wheels up launch, adjustment question [Re: Keith Richards] #2040183
03/28/16 12:55 AM
03/28/16 12:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Guys I KNOW a ladder bar acts like a anti roll
and IF things flex the bar helps it.. my car was
a ladder bar before I changed it.. my Rampage is
a ladder bar... and Doug is right.. those weights
are way off... the RR should show close to the
other side and then add a bit off preload.. if you
have a LOT of preload for the launch it does the
exact opposite on the shut down.. thats why you
dont want to add a lot... there are others on here
that have added a bar and it helped big time... and
I fought that idea.. but if you cant move weight..
then there is a problem
EDIT
JMO but I would see if I can move 150# to the RR
and with that 20# you might not need any preload
or you would be adding a small amount
wave
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040289
03/28/16 08:55 AM
03/28/16 08:55 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Anyone who runs roundy round could see that the cross weight is light. If this is a coil over suspension, just increase pressure L/F and R/R . That will decrease pressures on opposite cross weights at the same time.
[image][/image]
Re: Wheels up launch, adjustment question [Re: sgcuda] #2040377
03/28/16 01:00 PM
03/28/16 01:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just a reminder, when jacking weight around, especially on a ladder bar car, don't forget to remove one of the bar bolts at the housing, CANT JACK WEIGHT IF YOU DONT. Put something that is your weight in the seat (I used feed bags) then adjust weight. What the weights are before you're in the car means nothing. Driver side front should have more, back equal. When car launches that left front weight goes to right rear.
Re: Wheels up launch, adjustment question [Re: MR_P_BODY] #2040400
03/28/16 01:52 PM
03/28/16 01:52 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
[/quote]
He needs to put the anti roll on first then see
about air.. its loading the RR harder due to twisting..
if it applies equal load to both tires it might be fine
wave [/quote]
So what size anti roll bar? Is it one size fits all for the diameter?
Old Geezer Racing
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040428
03/28/16 02:34 PM
03/28/16 02:34 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Would a anti roll bar be good to have ???Yes but it is not the end of the world. A ladder bar car could be set up to go straight without one. It really needs to be put on scales with driver weight in seat and set up with about 20-30 lbs heavier on right rear than lt. he is 130 lbs light on the rt rear that is why it is going rt. left tire is working harder and driving the car rt.
JAKES AUTOMOTIVE
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040431
03/28/16 02:43 PM
03/28/16 02:43 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Agree with scale the car, and preload should fix it.
http://www.jerrybickel.com/complete-guide-to-chassis-performance-manual-rt-2000.html
buy Bickel's book best book on the subject. It covers a lot of four link, but ladder bars use same principles. Morgan's doorslammer book is good to, but Bickel's is written more with the racer in mind.
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040438
03/28/16 02:49 PM
03/28/16 02:49 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks everyone for your advice and suggestions..
I really didnt want to spend the money.. specially with TAXES due next month and all the other projects we have going on.. but I ordered a set of scales today and will re-weigh the car..
Thanks again all
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040446
03/28/16 02:56 PM
03/28/16 02:56 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Thanks again all
Hey BUDDY. Can I borrow them. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040459
03/28/16 03:15 PM
03/28/16 03:15 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I put an anti-roll in the Arrow and it was well worth the expense. It's a 4-link car and extremely narrow. To much pre-load and you can risk the car wanting to drive left or right down track.
5.53 @ 125 1/8th on the launch control..more left in her!
Page 2 of 3 1 2 3
