Re: 413 Truck Block Date Identification??
[Re: John_Kunkel]
#2043735
04/01/16 06:21 PM
04/01/16 06:21 PM
Posts: 300 MA
Greg55_99
MA
The water pump setup in that pic isn't correct, the industrial 413 has the water pump housing mounted high on the heads.
Exactly. So the water pump housing is not correct for those heads and the engine could not have run with what I see on it. Not only would the pulley's not line up but, as one can see, the head water passages are wide open to the world.
[Re: E-Ticket]
#2044047
04/02/16 12:08 AM
04/02/16 12:08 AM
Posts: 516 ND
dodgedon
ND
The picture's shown above are just like our 66 413 truck engine. As stated the water pump is high on the engine. The orange pump in your picture is typical car/pickup style and would not have run that way. I would say the distributor was also "Added" to this deal. These engines usually have a much larger distributor and governor setup. The exhaust manifolds are the same as our truck (CT800) and are unique to these heads. I would add one more thing... As stated the cranks are very heavy duty and I believe the rear flange may hang out the rear farther than typical RB car type cranks.
These 413 engines will handle "full throttle loaded work" all day long. But they only run 2500-3000 RPM max.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: Greg55_99]
#2046395
04/04/16 05:02 PM
04/04/16 05:02 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
G T 413 V 2 3
G= 1971 T= Trenton engine plant 413= Displacement V= Upside down A 2 3= Build date February 3
