Page 1 of 5 1 2 3 4 5
Toyota Alternator Upgrade #2039037
03/26/16 09:10 AM
03/26/16 09:10 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Has anybody have any amp problems? Which one you using? Any pics?
Re: Toyota Alternator Upgrade [Re: Scamp408] #2039172
03/26/16 01:46 PM
03/26/16 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using one for over 7 years from a 4-runner and it`s bad azz............fires up and shows 14.5-14.7 and powers everything nicely....... thumbs
Re: Toyota Alternator Upgrade [Re: Thumperdart] #2039180
03/26/16 02:07 PM
03/26/16 02:07 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Any more specific information on what model 4-runner? dont know much about them but i bet there may be a whole bunch of versions.
Also is it internaly regulated?
Late model alternator swaps are very intresting.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2039195
03/26/16 02:29 PM
03/26/16 02:29 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
just put one on my car, it's nice. 14.5 volts at idle.
probably gonna put an electric cooling fan on now coz so much voltage...
get the brackets that arengineering makes, lots of places sell them. mancini is one.
i forget what the alt part number is, the instructions that andy has on his site list all that. i just got a cheap rebuilt alt off of ebay and it works fine. already had the single groove pulley.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2039196
03/26/16 02:30 PM
03/26/16 02:30 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I just got the 60 amp one from a friend like new. It says 60 idle 80 at 4500 on tag is that why u guys running. I have msd electric fuel and a big spal fan I am also doing the electric water pump deal. The fan is the big sucker at 25 amps
Re: Toyota Alternator Upgrade [Re: 1Fast340] #2039226
03/26/16 04:06 PM
03/26/16 04:06 PM
AndyF Offline
AndyF  Offline
http://arengineering.com/home-page/alternator-kits/
Re: Toyota Alternator Upgrade [Re: Scamp408] #2039246
03/26/16 04:59 PM
03/26/16 04:59 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I use a denso #14611 off ebay. It fits an '87 Toyota Camry. My voltmeter is always at 14 and I've never had to charge the battery, love this setup!
Mine's hung off an AR-Engineering motor plate, He also sells the 3-wire pigtail for the denso alternator.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2039288
03/26/16 06:13 PM
03/26/16 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That sounds like the Viper 2 speed fan on low..
I use the 85A Denso with a external regulator...
I prefer the external regulator.. why trash a alt
because of the regulator went bad.. plus its a
easy test to see if the alt is putting out
wave
Re: Toyota Alternator Upgrade [Re: Scamp408] #2039312
03/26/16 06:49 PM
03/26/16 06:49 PM
Parts unknown
590 Challenger Offline
Parts unknown
I have 1 brand new 14611 left ($90 plus the ride), for $110 I can make it a 1 wire where you only need to run the battery cable, or make it 16 volt wire wire for the same. But I won't have more 16 volt regs for a week. If they ever go bad like P-body says, it only takes a couple Phillips screws to change them under the cover
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2039429
03/26/16 10:57 PM
03/26/16 10:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Bolt the Denso on and don't look back. Been working working with Denso alternators for over 30 years and seen ONE regulator failure. As much as we use our cars you will never need to buy another one and with Andy's kit it makes for a clean install.
Before I got the A/R kit I just used the motor plate to mount it.
Mine is off a 91 Toyota pick-up with a 22RE 4 popper.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040071
03/27/16 10:00 PM
03/27/16 10:00 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Was running the 22RE off an 85-92 4 runner (round plug and V belt). 60A and good idle charge characteristics. Andy's brackets.
Just picked up this, but haven't run it yet. Seller also has a 95A unit.
Can't say I'd recommend it yet, "reman-ed" unit was pretty rough, needing heli-coil, etc.
http://www.ebay.com/itm/180718768805?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040072
03/27/16 10:01 PM
03/27/16 10:01 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
i have one and love it
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040100
03/27/16 10:22 PM
03/27/16 10:22 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I bought one of these kits for the stock alt. ---seems to work great
http://store.alternatorparts.com/ho7005-chrysler-square-back-alternator-80-amp-upgrade-kit-1.aspx
Re: Toyota Alternator Upgrade [Re: 493_DART] #2040121
03/27/16 10:53 PM
03/27/16 10:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I need to do SOMETHING. I'm tired of the dim lights at idle. I'm not sure I want to rewire the whole dang car, though. The jumper from the alternator to the starter doesn't bother me but...
Re: Toyota Alternator Upgrade [Re: GY3] #2040249
03/28/16 02:01 AM
03/28/16 02:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A simple fix is to use the halagon lights.. you
dont need to rewire.. they draw way less.. but a
new style alt helps out.. I run the denso 85a and
run a lot of elec stuff and injection... the volts
set at 14.7 at idle
EDIT
I run this light on my Rampage.. its bright and
has a perimeter of white leds and a inner small
light that I also have hooked up to my turn signal
wave
Re: Toyota Alternator Upgrade [Re: GY3] #2040376
03/28/16 12:00 PM
03/28/16 12:00 PM
AndyF Offline
AndyF  Offline
Dim lights at idle is the whole reason why I came up with the Denso swap kit years ago. The Mopar alternator is very lazy at idle while the Denso cranks out a bunch of amps. Just the difference that 50 years of R&D makes I guess. Plus the Denso alternator is 5 lbs less weight to drag around and it seems to be a very reliable design. My wife has more than 200K miles on her 4Runner and the alternator is still going strong.
Re: Toyota Alternator Upgrade [Re: MR_P_BODY] #2040381
03/28/16 12:04 PM
03/28/16 12:04 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Seems like amperage is like money.(there's NEVER enough).
I bought a Powermaster rated @90A and still loose a little ground @idle. Of course my load combined is 46 amps and I have an underdrive pulley. The alt has been measured @ 90 amps when the engine revs some.
Yeah, it's got a smallblock.
Re: Toyota Alternator Upgrade [Re: MR_P_BODY] #2040383
03/28/16 12:19 PM
03/28/16 12:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
set at 14.7 at idle
EDIT
wave
That`s a great idea...........I have the older halogens which help but that may be my next step if they`re that much better...........
Re: Toyota Alternator Upgrade [Re: AndyF] #2040386
03/28/16 12:25 PM
03/28/16 12:25 PM
fullmetaljacket Offline
Andy.
Are you talking about the 60 amper?
I have an electric fuel Aeromotive 1000 HP pump in the tank, electric caravan cooling fan, all working dash cluster, turn signal/brake lights and headlights, Firecore distributor and CD coil.
No Radio, no heater, and or other accessories. That's it.
Re: Toyota Alternator Upgrade [Re: Thumperdart] #2040388
03/28/16 12:28 PM
03/28/16 12:28 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Those that need really high Amp alternator look into mechman alternator..high in price but works really well..my son is in to car audio sound competition car has 6 batteries total and 1 of the alternator works great and he drives the car..moving up in competition he's going to add another alternator on a custom mount to run the both ..this is a 2001 maxima..
Re: Toyota Alternator Upgrade [Re: 340B5] #2040390
03/28/16 12:29 PM
03/28/16 12:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In your case the under drive may be the reason
you still have a idle issue.. if you had the stock
rpm ratio it would most likely take care of it..
they still need to turn X rpms at idle to have a
positive output(that will exceed your total draw)
EDIT
I can see a fluctuation at idle if the fan kicks on
and it has a rpm drop(before the AIS kicks it back up
so that can last maybe a second
wave
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040412
03/28/16 01:01 PM
03/28/16 01:01 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have ran the Mopar denso before and when my fan comes on my idle drops bad.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040421
03/28/16 01:20 PM
03/28/16 01:20 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I checked the 14611 on the bag, $63 so not a bad price. It looked like all of them were set up for a ribbed belt. Where can you get the correct pulley?
Re: Toyota Alternator Upgrade [Re: justinp61] #2040425
03/28/16 01:32 PM
03/28/16 01:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine`s a v-belt from Kragens and would rather buy locally w/a warranty than on line but that`s just me...........
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040479
03/28/16 02:44 PM
03/28/16 02:44 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
How much do these Toyota alternators weigh?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Toyota Alternator Upgrade [Re: justinp61] #2040493
03/28/16 03:04 PM
03/28/16 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made my pulley but I'm sure that someone sells
the pulley... I wanted a deep pulley
wave
Re: Toyota Alternator Upgrade [Re: Hemi_Joel] #2040551
03/28/16 04:33 PM
03/28/16 04:33 PM
Rittman Ohio
Rittman Ohio
Well I'm at work here in the Toyota shop and I just threw a pick-up alternator on the scale and it weighs almost 10 pounds.
Some are lighter but this one is a 90 amp 2000 Tacoma alternator.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Toyota Alternator Upgrade [Re: AndyF] #2040617
03/28/16 06:53 PM
03/28/16 06:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So does this alternator have the balls to run an EFI pump, HHR fan, electronic ignition as well as lights, etc. ?? If not, what sort of amps would it take?
Re: Toyota Alternator Upgrade [Re: Hemi_Joel] #2040640
03/28/16 07:25 PM
03/28/16 07:25 PM
More or less 10 Lbs.
Re: Toyota Alternator Upgrade [Re: Stanton] #2040657
03/28/16 07:47 PM
03/28/16 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 85 amp Denso I run does it without issue
wave
Re: Toyota Alternator Upgrade [Re: Stanton] #2040668
03/28/16 08:01 PM
03/28/16 08:01 PM
AndyF Offline
AndyF  Offline
Well new cars have all of that and more and the OEM engineers don't seem to have any problems putting these Denso alternators on new cars. My wife's 4Runner even has heated seats and stuff like that which you aren't going to find in any muscle car.
Re: Toyota Alternator Upgrade [Re: Stanton] #2040669
03/28/16 08:02 PM
03/28/16 08:02 PM
Rittman Ohio
Rittman Ohio
I ran an HHR fan,electric water pump,fuel pump, lights,and my MSD ignition and the volts dropped to 13.5 at 900 RPM with the brakes on at a light. That was with the 60 amp unit that I pulled of a cash for clunkers car 8 years ago. This conversion is the best update you can do for your car. Just imagine sitting at a light and your head lights don't dim like a pee-hole in a snow bank. The one thing I do strongly suggest is that you go with a factory Denso re-man unit over a P.O.S. Ebay junker. I have never had a problem with Denso rebuilt parts but I have seen dozens of cheapo re-builds crap out or not work at all.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040853
03/28/16 11:11 PM
03/28/16 11:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Anyone have a line on V belt pulleys? I went to a junk yard a couple weeks ago looking for one, lots of them on 4 cylinder cars but all had ribbed belts.
Re: Toyota Alternator Upgrade [Re: Thumperdart] #2040860
03/28/16 11:18 PM
03/28/16 11:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Same here, I had one go out and got a free replacement from autozone. The first one only lasted about 8k but maybe it's due to the 6,500rpm shifts or heat.
Re: Toyota Alternator Upgrade [Re: ademon] #2040864
03/28/16 11:32 PM
03/28/16 11:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Screw saving a few bucks cos when I try that it bites me so I buy where I shop locally and NO questions asked..........
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040870
03/28/16 11:41 PM
03/28/16 11:41 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have the unit from 440Source which I believe is one of Andy's products.
The unit Andy sells has a v-groove pulley - maybe he can help you with that. Otherwise, try an alternator/starter repair shop - those guys will usually have crates of pulleys from cores. Measure the shaft first 'cause its likely metric and there are two sizes.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040882
03/28/16 11:55 PM
03/28/16 11:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A new one from any of the parts stores requires a $35-50 core charge.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2040893
03/29/16 12:11 AM
03/29/16 12:11 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Rock auto has them with a V groove pully
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Toyota Alternator Upgrade [Re: Thumperdart] #2040984
03/29/16 04:29 AM
03/29/16 04:29 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
You are not alone!
Re: Toyota Alternator Upgrade [Re: Scamp408] #2041074
03/29/16 10:26 AM
03/29/16 10:26 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
if you can deal with only 60 amps then look up the part number for something like an 85 toyota pickup, it will have a v groove pulley.
rockauto is a good place to get the part number.
Re: Toyota Alternator Upgrade [Re: krautrock] #2041124
03/29/16 11:43 AM
03/29/16 11:43 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s exactly what I run and I bought it right around the corner so when it fails, I walk in and get another not wait 3-5 days..........
Re: Toyota Alternator Upgrade [Re: Scamp408] #2041240
03/29/16 03:01 PM
03/29/16 03:01 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Anybody make the spacers to use the Moroso small block water pump or is it a fab your own deal
Re: Toyota Alternator Upgrade [Re: justinp61] #2041243
03/29/16 03:14 PM
03/29/16 03:14 PM
AndyF Offline
AndyF  Offline
V belt pulleys are easy to find, several mfgs make them. If you're looking for a Denso alternator with a v belt pulley then just order one from 440Source or Mancini or anybody else who carries the kit. Or just get one from a local supplier. If you want to go to a wrecking yard then download the instructions from my website. All of the part numbers are on there.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2041250
03/29/16 03:26 PM
03/29/16 03:26 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have run my 68 charger for 3 years with toyota alternators. I burned one up and had to buy another.
I ran an electric fuel pump, electric fan, msd, stereo, etc... and still had problems with good idle voltage. Everything would be fine until I turned on the A/C which would automatically turn on the electric fan.
At speed I was fine but not at idle.
I installed a powermaster 140 amp gm style alt. 90 at idle. Which is what I installed 4 years ago on my 67 Coronet which has a bigger mercedes electic fan and msd atomic system and fuel pump plus A/C. Never had any inkling of a voltage problem.
While the toyota alternators worked ok they were always working hard which isn't good for the life span.
Using a higher amp alternator with an easy duty cycle or load will make it last longer.
Re: Toyota Alternator Upgrade [Re: rapom] #2041351
03/29/16 06:22 PM
03/29/16 06:22 PM
Parts unknown
Parts unknown
I do starters and alternators for a living (sad I know) the Toyota alternators (Denso) will out last the Delco style. Maybe you got poorly rebuilt or needed more amps then it could give. But by far the Denso will out last in it's amp range. You step a Delco up in amperage it will shorten it's life even more. The later style hair pin Denso are light years better than either, but the price reflecks it. If I was looking to put a 140 amp alternator on a hot rod and make brackets, I would use this off a John Deere, factory 140 Amp (which really charge more), much power at an idle. You can put in 1 wire regulators, use normal, GM and Ford Pulleys. If you want the advise of someone that sells thousands of starters and alternators a month, here it is
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2041357
03/29/16 06:34 PM
03/29/16 06:34 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I guess I will look into those John Deere units if my gm ones go bad.
Re: Toyota Alternator Upgrade [Re: rapom] #2041363
03/29/16 06:45 PM
03/29/16 06:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I can only guess what JD would charge for it.. Deere
doesnt have anything cheap
wave
Re: Toyota Alternator Upgrade [Re: Scamp408] #2041367
03/29/16 06:55 PM
03/29/16 06:55 PM
Parts unknown
Parts unknown
John Deere Number RE46608, TY6762
Denso Number 100211-6420
It comes with an 8 groove pulley, I sell for $110, $10 if you need another pulley, $20 more if you want 1 wire or 16 Volt 1 wire. Or use the part numbers to look else where.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2041576
03/29/16 10:59 PM
03/29/16 10:59 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
How does that compare in physical size to the CS130 GM Unit?
68 Barracuda Formula S 340
Re: Toyota Alternator Upgrade [Re: Scamp408] #2041761
03/30/16 09:34 AM
03/30/16 09:34 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
And size wise to the Toyota alt
Re: Toyota Alternator Upgrade [Re: Scamp408] #2041831
03/30/16 11:04 AM
03/30/16 11:04 AM
Parts unknown
Parts unknown
The John Deere alternator is a work horse. It’s great for street hot rods with lots of radio and power everything, will charge great at an idle. I can’t see people of saying they were burning the Toyota ones up at the track?? The Toyota if they have brackets available is a pretty good choice.
John Deere 14.04 lbs, Body Dia. 5.4”
Toyota 9.88 lbs, Body Dia. 4.5”
CS130 11.4 lbs, 5.25” (130 centimeters, it’s where it got its name)
Baby Denso 6.39 lbs, 3.75” body (little heavier in 80a mode)
The John Deere alt would be great for cruising a hot rod with many accessories. CS130 is a pretty good choice for firing your car down the strip or even street driving (sometimes have issues at idle if you try to step them up too much), lighter and economical. Baby Denso would be great for the track, I really wouldn’t recommend it for street stip. A stock one makes 35-40 amps, I have special hand windings made to make them 80 amps and would be great for the track, hand winding is expensive and it won’t have the power at the idle or durability of the others. All can be made 1 wire, or 16 volt pretty easy.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2042029
03/30/16 02:55 PM
03/30/16 02:55 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Take a look at Moroso #63815
Re: Toyota Alternator Upgrade [Re: Scamp408] #2042789
03/31/16 03:33 PM
03/31/16 03:33 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
What about the denso 100211-603 or 605
Re: Toyota Alternator Upgrade [Re: Scamp408] #2042819
03/31/16 04:23 PM
03/31/16 04:23 PM
Parts unknown
Parts unknown
120 amp, it's a good choice
Re: Toyota Alternator Upgrade [Re: Scamp408] #2042833
03/31/16 04:35 PM
03/31/16 04:35 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Is this a I between size case wise 60-140. I have a new reman 60 and a Mopar denso 90 when I get the new pump in will see what will fit. All I know is with the 90 my idle rpm drops a lot when the fan comes on but volts are good.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2042848
03/31/16 04:59 PM
03/31/16 04:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Is there a way to identify the different denso alternators?
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2043336
04/01/16 07:45 AM
04/01/16 07:45 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
My stock 70 Challenger alt weighs 13lbs... really not much ov a savings? I thought the Toyota ones would be lighter?
Could the 'baby' ones be that bad for the street? What if my car is running very little in terms ov options? Electric fuel pump, a stereo, heater, lights, wipers, etc... not much else.
Re: Toyota Alternator Upgrade [Re: justinp61] #2043343
04/01/16 08:11 AM
04/01/16 08:11 AM
Parts unknown
Parts unknown
I pay to use a website, if I were you I would just google the number on the alternator
Re: Toyota Alternator Upgrade [Re: Pale_Roader] #2043352
04/01/16 08:29 AM
04/01/16 08:29 AM
Parts unknown
Parts unknown
The Baby one is like putting a big cam in your car, sure it will make power but only on the high end, at idle it won't make squat. Your car will be running off your battery until you bring it into higher RPM's. Also as you know alternators work from magnetizam. You can only magnetize something so much before it starts building heat. Putting that much power out of a small one would take a lot of magnetizam. Heat will make it less efficient (making it work even harder yet) and way more likely to burn up and fail. When your driving down the street it would be working much harder than a normal 80 amp, it will be try to make up the power your battery lost at the stop light where a normal one would have been making a charge. Great for drag cars
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2043356
04/01/16 08:34 AM
04/01/16 08:34 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Damn... the idea ov losing almost 7lbs off the engine had me in fits there for a second...
Do they get smaller/lighter than the 9.88lb Toyota one?
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2043372
04/01/16 09:30 AM
04/01/16 09:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I did but couldn't find what I was looking for. The reason I asked is that I've found plenty of alternators on 4 cylinder cars and I've found sources for the pulley. If the cars are the same physically as the early 90's 4 runner and trucks I'll buy one of them.
I'll figure it out.
Re: Toyota Alternator Upgrade [Re: justinp61] #2043411
04/01/16 11:08 AM
04/01/16 11:08 AM
Rittman Ohio
Rittman Ohio
All the car alternators have rib belts with the exception and some early 80's rear drive cars. You should just find the correct one that fits the brackets that Andy makes and save some time messing spacers and bolts.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043414
04/01/16 11:11 AM
04/01/16 11:11 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Is that case size frt to back and does include the pulley. I measured the Toyota I have and got 4-7/8 frr to back and 5-3/4 with pulley.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043844
04/01/16 07:13 PM
04/01/16 07:13 PM
Parts unknown
Parts unknown
if you are asking me, I measured the diameter of the round part of the alternator body
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043863
04/01/16 07:40 PM
04/01/16 07:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
14433 is the denso dodge alternator at autozone with a V belt. Bout $100 and is made to fit a dodge.
14430 is the denso dodge alternator at autozone with rib belt. Bout $100 and is made to fit a dodge.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2043894
04/01/16 08:29 PM
04/01/16 08:29 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am looking at using a 137 amp denso out of a Durango, can I get a V belt pulley for it? What vehicle is the Baby denso from? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Toyota Alternator Upgrade [Re: astjp2] #2043915
04/01/16 08:56 PM
04/01/16 08:56 PM
Parts unknown
Parts unknown
Kubota tractor, stock is 35 amp
Re: Toyota Alternator Upgrade [Re: fourgearsavoy] #2043920
04/01/16 09:03 PM
04/01/16 09:03 PM
AndyF Offline
AndyF  Offline
Gus beer
Seems like the easy solution to me too. I have the part numbers and the cross reference numbers on my website. Wiring instructions and pictures are also there.
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2043989
04/01/16 10:13 PM
04/01/16 10:13 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
My problem is the depth.I
Have a new Toyota alt but if I can fit the bigger one I may go that route on the dohn Deere one you sell.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044010
04/01/16 10:35 PM
04/01/16 10:35 PM
Parts unknown
Parts unknown
I had that issue when I had my motor plate, maybe you do too? When I was running an alternator off my motor plate I ran one of these. It's a GM alternator CS130D (D is for double internal fan, gving better cooling) they also work much better than the CS130 that many people use because it use larger bearings. Small bearings have been known to have been a issue on the CS130. I spaced out the long ear to pivot under the motor plate, keeping it out of the way. Stock 105 amp.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044271
04/02/16 09:15 AM
04/02/16 09:15 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have the AR kit for the denso 60 but was curious the depth on the higher amp denso
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044359
04/02/16 11:09 AM
04/02/16 11:09 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I am using a DENSO for a John Deere tractor.
120 Amps!!!
The case is slightly deeper over the car alternators, but they fit just fine!
Ryan
http://www.dbelectrical.com/p-5958-alter...CFZNhfgod3GYDDg
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2044380
04/02/16 11:32 AM
04/02/16 11:32 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think I have the one slightly bigger than the baby one. IIRC it's listed at 6.7 lbs 102mm one. It's for a Suzuki Samurai (remember those). IIRC, listed at 45 amps.
Looking at the powermaster website it's only slightly heavier than the baby-ultralight at 5.75 lbs
Mine does great at idle. It was a very noticeable improvement over my stock Chrysler alternator at idle with lights on. I have don't have a electrical fan or fuel pump. No radio either.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: Toyota Alternator Upgrade [Re: fourgearsavoy] #2044387
04/02/16 11:41 AM
04/02/16 11:41 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Gus beer
Pulleys are cheap and I can get a car alternator guaranteed to work for $20. Plus I like fabricating, it's part of hot rodding IMO. Otherwise I'd just be a parts changer.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2044395
04/02/16 11:50 AM
04/02/16 11:50 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My 70 amp #14611 was only about $60 on ebay, the pulley can be bought from Summit Racing(made by Canton Racing iirc), or from AR-Engineering. Fits great on a motor plate.
Re: Toyota Alternator Upgrade [Re: redmist] #2044634
04/02/16 05:53 PM
04/02/16 05:53 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
120 Amps!!!
Ryan
dumb question time...so alternators meant for low RPM diesels will have no problems with high RPM motors??
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Toyota Alternator Upgrade [Re: jughed] #2045155
04/03/16 09:52 AM
04/03/16 09:52 AM
Parts unknown
Parts unknown
Diesel alternators as a rule of thumb always have better bearing than cars and are balanced the same way. Don't eve be afraid to use them. The durango alt the one guy was using has the same bearings, good choice
Re: Toyota Alternator Upgrade [Re: Scamp408] #2045162
04/03/16 10:08 AM
04/03/16 10:08 AM
Parts unknown
Parts unknown
The 120 amp JD and the 140 amp are the same size and use the exact same cases. I measured 5 3/8" but that is with the standard 8 groove pulley. Maybe a pic will help you decide??
Re: Toyota Alternator Upgrade [Re: Scamp408] #2045173
04/03/16 10:23 AM
04/03/16 10:23 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Thanks for the measurement. So it's like 7\16 deeper than the Toyota one.
Re: Toyota Alternator Upgrade [Re: 590 Challenger] #2045200
04/03/16 11:05 AM
04/03/16 11:05 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Is that 5 3/8" from the front of the case to the back?
Re: Toyota Alternator Upgrade [Re: Scamp408] #2045335
04/03/16 01:21 PM
04/03/16 01:21 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I measured 5" from front to rear of case on Denso 210-0106 (Toyota 60A, V belt)
Re: Toyota Alternator Upgrade [Re: Scamp408] #2047331
04/05/16 06:48 PM
04/05/16 06:48 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I am gunna test fit with toyo alt once I get my pump. If I have room it looks like I need the JD one.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2047735
04/06/16 08:51 AM
04/06/16 08:51 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I eyeballed mine last night. I have Andy's brackets on a RB, and it looks like I have enough clearance to the head, just not sure how close the 3 pin plug will come to #2 primary.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2048192
04/06/16 05:35 PM
04/06/16 05:35 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The small blocks are tight especially with aluminum heads
Re: Toyota Alternator Upgrade [Re: Scamp408] #2048475
04/06/16 10:56 PM
04/06/16 10:56 PM
Victoria B. C Canada
gold66cuda Offline
gold66cuda  Offline
They are, in fact I had to notch the front of the head for my 70 amp unit to fit. This was on and early small block with the cast iron water pump though.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2048480
04/06/16 11:01 PM
04/06/16 11:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made a bracket that mounts on the fuel bolts..
I use the 85a denso
wave
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061582
04/25/16 06:22 PM
04/25/16 06:22 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Just got an alternator from a 97 4Runner today. The plug is different than the one Andy has for sale but I'm sure I can figure it out. Gonna call powermaster about a pulley.
eBay-cdwmotorsports
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061795
04/26/16 12:14 AM
04/26/16 12:14 AM
Martinsville, IN
Martinsville, IN
The shaft measures out around .52" and the pulley is 2.4" in diameter.Powermaster was closed and nothing in their catalog seems as if it will fit. Any other sources for a pulley?
eBay-cdwmotorsports
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061882
04/26/16 07:30 AM
04/26/16 07:30 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I got my pulley from a briggs Stratton dyhaitsu diesel engine for a Toro 3250 golf course mower. It's comes off a small denso alt 40amps
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061883
04/26/16 07:31 AM
04/26/16 07:31 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I fitted up the 60 amp and have a little less than a1\4in between head and back of alt.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2062753
04/27/16 03:02 PM
04/27/16 03:02 PM
NWPA
Q
QMopar Offline
QMopar  Offline
Q
NWPA
What are the bracket options for folks running a big block with AC?
Re: Toyota Alternator Upgrade [Re: QMopar] #2062935
04/27/16 07:01 PM
04/27/16 07:01 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here's the kit I used but I used a Gm powermaster alt.
http://bouchillonperformance.com/inc/sdetail/467/571
They have another bb kit also.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2062956
04/27/16 07:34 PM
04/27/16 07:34 PM
Martinsville, IN
Martinsville, IN
Jones Racing Products sells a pulley, that's who Powermaster sent me to for a V groove pulley.
97 4Runner alternator takes part #AL-3105-B-A-2.375 if you are running a DMI pulley
eBay-cdwmotorsports
Re: Toyota Alternator Upgrade [Re: Scamp408] #2063026
04/27/16 09:25 PM
04/27/16 09:25 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Jones is a killer place, super nice products and quality.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Toyota Alternator Upgrade [Re: Scamp408] #2064191
04/29/16 06:34 PM
04/29/16 06:34 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Ran it today with the 60amp toyota and all was good fan came on volts went down but came up and stabilized.Only issue I have and had is when the fan comes on the rpm drops alot no matter what i do.Happens with 90 amp denso mopar ext reg alt also.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2065276
05/01/16 01:29 PM
05/01/16 01:29 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Wondering if this drop in rpm will happen with the 120or 140 JD unit
