engine paint #2038601
03/25/16 05:27 PM
03/25/16 05:27 PM
usa
lewtot184 Offline OP
usa
i'm looking at painting an engine, not sure if i want turquoise or street hemi orange. anyhow, has the mopar performance direct connection paints gotten any better? last i bought was beyond horrible. what about plasti kote 226 street hemi orange? is it still available and if so where to buy? thanks.
Re: engine paint [Re: lewtot184] #2038611
03/25/16 05:49 PM
03/25/16 05:49 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What year/engine are you painting? What level of accuracy are you after? If you want a really good match to either color I like Frank Badelsons paint (sixpackfrank@aol.com). You'll need a gun or a Preval sprayer to apply it. Preval Sprayer .
Re: engine paint [Re: lewtot184] #2038624
03/25/16 06:30 PM
03/25/16 06:30 PM
usa
usa
this isn't any restoration thing. just putting together a spare and want something the coats fairly well, holds up, and a little gloss.
Re: engine paint [Re: lewtot184] #2038647
03/25/16 07:06 PM
03/25/16 07:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
In that case your better off with the Plasti-cote Hemi-Orange
Re: engine paint [Re: DAYCLONA] #2038649
03/25/16 07:09 PM
03/25/16 07:09 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I second the Plasti-Kote hemi orange. Color is not exactly stock, but durability and coverage are great. It's a little glossier than stock, too.
Make sure your prep work is good--have to get it white-glove oil free.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: engine paint [Re: lewtot184] #2038708
03/25/16 08:16 PM
03/25/16 08:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
VHT. I'm told the color is not correct, and the gloss is wrong. I like it. It applied nicely and is holding up well.
Re: engine paint [Re: lewtot184] #2038745
03/25/16 09:08 PM
03/25/16 09:08 PM
usa
usa
russ, i like the gloss; easier to keep clean. is that turquoise or blue?
i used to use plasti kote hemi orange but can't find it any more. guess mopar is the only one who has turquoise,.....?
a couple of years ago i had a guy mix me up some dupont centari in hemi orange, worked great, but i think you can't buy the dupont centari anymore.
Re: engine paint [Re: lewtot184] #2038759
03/25/16 09:35 PM
03/25/16 09:35 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
There's also Eastwood and bill Hirsch
Re: engine paint [Re: lewtot184] #2038789
03/25/16 10:14 PM
03/25/16 10:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Turquoise. It is easier to keep clear.
Too bad about the Centari. I always had good luck with it, and I'm a hack.
Re: engine paint [Re: lewtot184] #2038802
03/25/16 10:34 PM
03/25/16 10:34 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Gettin' good life out of MP 'engine paint'...
Over primer...
Re: engine paint [Re: RSNOMO] #2038840
03/25/16 11:19 PM
03/25/16 11:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you I am not happy with the Dupli-Color paint I used on my eng this time. Course I had the same problem with the MP paint as everyone and I liked the color of this Dupli-Color as they call it Hemi Orange. I put this eng in the car in 2011 and the paint held up ok for a few years but the last year or so its started to peel in spots on the intake , heads , oil pan and block a little. I touch it up where I can get to it and even use a brush in some spots but I am not happy with the Dupli-Color and wont use it again. I prepped my block and parts like I always have and I have had good luck with eng paint until I used this Dupli-Color this time. Heck I might pull the eng just to repaint the whole eng this winter. Ron
Re: engine paint [Re: BSB67] #2038856
03/25/16 11:40 PM
03/25/16 11:40 PM
usa
usa
when i got into the centari mixing and fumbling with my little chinese gun i was just one step above finger painting but preferred it over spray bomb.
Re: engine paint [Re: lewtot184] #2038882
03/26/16 12:16 AM
03/26/16 12:16 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
I got in a jam and ended up using a couple different brands last time for orange. Duplicolor wouldn't cover and ran in heavy coats, but had good gloss and correct-ish gold flake. VHT covered well but dried darn near flat with no metal flake. Next time around I'm going to try VHT as a primer/base coat with a light coat of dupli color over it for the finish.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: engine paint [Re: lewtot184] #2038908
03/26/16 12:37 AM
03/26/16 12:37 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
This is what I use and it is great, goes a long way, could paint 4 or 5 engines with a 1ltr tin.
http://www.por15.com/ENGINE-ENAMEL_p_47.html
1963 Plymouth Max Wedge
1971 Barracuda
Re: engine paint [Re: lewtot184] #2038920
03/26/16 12:46 AM
03/26/16 12:46 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Regardless of color or gloss single stage urethane will give the best durability. Unaffected by brake clean, carb clean, etc. You can get any color or gloss. Clean with DX 440, epoxy prime and spray. I have stuff that looks like this that is 20 years old.
Doug
Re: engine paint [Re: ozymaxwedge] #2039059
03/26/16 11:17 AM
03/26/16 11:17 AM
usa
usa
that little slant 6 is cool!
Re: engine paint [Re: lewtot184] #2039060
03/26/16 11:18 AM
03/26/16 11:18 AM
usa
usa
a lot of good ideas here.
Re: engine paint [Re: dvw] #2039102
03/26/16 12:23 PM
03/26/16 12:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Doug
Agreed. You wouldn't use spray cans on any other part of your car and expect it to hold up, yet when it comes to engines we're still stuck on spray cans.
Re: engine paint [Re: DaytonaTurbo] #2039428
03/26/16 11:57 PM
03/26/16 11:57 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i use the eastwood urethane,pretty good so far ,about five years now.had to touch up a few spots from wrenchin but just used a little brush.
Re: engine paint [Re: dvw] #2039450
03/27/16 12:22 AM
03/27/16 12:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Doug
Doug where do you get that paint you used on your 64's eng as I really like that ? Ron
