Yoke- U joint ?????????'s #2038430
03/25/16 01:03 PM
03/25/16 01:03 PM
Creston, Iowa
3
340man4ever Offline OP
Creston, Iowa
Have a buddy finishing a drag car that needs to update his yokes / driveshaft combo.
3300 lb car, 630 Hp now, probably down the road no more than around 800 Hp under the hood.........
727 trans / going to Dana 60 rear
1350 U joints the right size for this?
How about the the slip and pinion yokes?
I see them in iron /steel
Ductile Iron
Moly
Billet
Which yoke material would be the best value for the future power goals?
Thanks in advance help
Curator at Adams County Speed Shop
Re: Yoke- U joint ?????????'s [Re: 340man4ever] #2038468
03/25/16 02:00 PM
03/25/16 02:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running the 1350 stuff for 13+ years and they still look/feel great...........And the yoke is forged steel from Drdiff..........
Re: Yoke- U joint ?????????'s [Re: 340man4ever] #2038477
03/25/16 02:08 PM
03/25/16 02:08 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
1350s are fine. Use the good HD units, not the hollow joints with grease fittings.
I would use something like a Strange CM yoke, U1598, and a good slip yoke like the Strange U1666. These aren't the cheapest option, but it's less money than would you would spend to fix the car if the shaft comes out of it. I have a nice transmission here right now with expensive damage from a broken driveshaft. The HD forged parts are around half the money and may be fine for your application until you really step up the power level.
Make sure you figure shaft length with the parts you will be using. This stuff is not all made to the same dimensions.
I have had less than good luck using local sources for driveshafts for race cars. They may be fine for a shaft for an old pick up, but they just don't seem to get the RPM they are spun to in a race car. Your area may be different or you may opt to have someone like Strange, Mark Williams, Dynotech, Denny's or someone similar build your shaft.
Re: Yoke- U joint ?????????'s [Re: CMcAllister] #2039442
03/27/16 12:12 AM
03/27/16 12:12 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Strange has a smokin deal on driveshafts right now you need to check their site.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Yoke- U joint ?????????'s [Re: 340man4ever] #2039766
03/27/16 03:25 PM
03/27/16 03:25 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Billet no problems ever, drag radials and nitrous. I've broken after market axles and no yoke problems
Re: Yoke- U joint ?????????'s [Re: SpareParts] #2039873
03/27/16 05:51 PM
03/27/16 05:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
IF a new shaft is needed call Dyntech.. they have
all the different parts and will have yokes.. they
are the only place I deal with in the last 10 years
and they have great products and quality
wave
