Painting your block. #203791
01/25/09 11:23 AM
01/25/09 11:23 AM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
So when I walk around the pits and check out other peoples cars, one thing that impress' me the most is a clean engine bay, well put together and thought out. No after thoughts, or sloppy hoses.
In the center of this is a nice shiny orange hunk of steel...
What have you guys found to be the best way to do this for appearance and durability.
Is it a primer, or particular paint. With a fresh block from a machine shop, do you wipe it down with thinner or acetone???
I know the veterans will have the answer
Re: Painting your block. [Re: joshking440] #203792
01/25/09 01:54 PM
01/25/09 01:54 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
1) Jet wash and dry
2) Lacquer thinner and dry
3) DP type primer
4) Single stage Urethane..will look and last new forever with an easy to clean gloss.
RIP Monte Smith
Re: Painting your block. [Re: CompWedgeEngines] #203793
01/25/09 02:28 PM
01/25/09 02:28 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Re: Painting your block. [Re: PLUM BAD] #203794
01/25/09 03:10 PM
01/25/09 03:10 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I like to paint everything individually, block, heads, oil pan, front cover, valve covers, water pump housing. It takes more time to mask everything off, but I like the look with bright fasteners. This is a race car, not for show.
Re: Painting your block. [Re: cgall] #203795
01/25/09 03:28 PM
01/25/09 03:28 PM
Syracuse,NY
Syracuse,NY
I agree and typically do the same. I like to paint the blocks so when I am working on them dduring the build, it is much easier to clean ( which often times is 2 or 3 times)and you dont have to worry about flash rusting so much. I almost do everything in Urethane, so I'll prep the pieces then just paint them when the block is getting painted as well. I too like the looks of fresh fasteners. It takes a lot of time to do it this way, but the results are always excellent and my customers have come to know me for clean, nice looking engines as well.
RIP Monte Smith
Re: Painting your block. [Re: CompWedgeEngines] #203796
01/25/09 04:26 PM
01/25/09 04:26 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my block & heads are 2 pot baked enamel. was trying to hide the fact they were aluminium but the silver is obvious in places the painter masked off. mine is 4 seasons old & still looks like new.
Re: Painting your block. [Re: rebel] #203797
01/25/09 04:29 PM
01/25/09 04:29 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
another
Re: Painting your block. [Re: rebel] #203798
01/25/09 04:30 PM
01/25/09 04:30 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
So does this mean I need a spray gone and or a very large oven...
I assume the urethane is a spray gun only application
The baked enamel it is in fact baked?
Re: Painting your block. [Re: joshking440] #203799
01/25/09 04:52 PM
01/25/09 04:52 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
being an alloy block it was media blasted first, then put in a powerwash machine, then masked, heated & then sprayed like a car, then baked for 4 hours. it's a very hard surface. my local ceramic coating applicator did it for me for 2 trays of beer. it was a trial on a new product & we were both impressed with the result,
Re: Painting your block. [Re: rebel] #203800
01/25/09 05:17 PM
01/25/09 05:17 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Got ya. I picked up my short block completly assembled and would rather not take it back apart.
I think I can mask it off and spray it with urethane...I hope
Re: Painting your block. [Re: joshking440] #203801
01/25/09 05:27 PM
01/25/09 05:27 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
honestly i get lots af spectators in the pit wanting to touch my block & heads, it looks sooo smooth & shiney. i don't think you'll have any probs painting the complete assy. just remember to run around with a razor blade on all your joints before it sets real hard. this will make it come apart easier without ruining your finish.
Re: Painting your block. [Re: rebel] #203802
01/25/09 07:44 PM
01/25/09 07:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I never would have thought about running a razor blade around the joints, good info.
I usually paint mine apart as I like the clean line look of the gaskets etc. However it would be easier to just spray the whole thing.
68 Barracuda Formula S 340
Re: Painting your block. [Re: joshking440] #203803
01/25/09 07:47 PM
01/25/09 07:47 PM
Canada
CrAzYMoPaRGuY Offline
Canada
LOL
Let me terrify you all by saying the best engine paint I have found is Tremclad paint in a can, applied by a brush.
It turns out smooth with no brush marks, takes tremendous amounts of heat before discoloring, and stays shiny, clean, and does not fade or peel.
Easy to touch up too.
CrAzYMoPaRGuY
Re: Painting your block. [Re: CrAzYMoPaRGuY] #203804
01/25/09 08:14 PM
01/25/09 08:14 PM
I usually paint my motors after there assembled, mask as needed and buy several cans of Mopar engine paint or your favorite brand and color and I do make sure that all the oil is rinse off with a good brand of petroleum based cleaning solvent and then a quick rinse with laquer thinner and then use a face mask or resperator as some of the paints are not good for your lungs Be careful of sparks also
Re: Painting your block. [Re: CrAzYMoPaRGuY] #203805
01/25/09 08:15 PM
01/25/09 08:15 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Motor out of machine shop on engine stand.Brk clean off assm oil residue,comp air dry,plasticoat engine primer,let dry ,mopar orange 2 to 3 coats .
Re: Painting your block. [Re: Scamp408] #203806
01/25/09 08:18 PM
01/25/09 08:18 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Too bad it's difficult to recreate the factory sheen with it's thin coat semigloss look..any suggestions there?
Re: Painting your block. [Re: Hot 340] #203807
01/25/09 08:54 PM
01/25/09 08:54 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
i clean everthing with brake parts cleaner. then mask everything indavidually, prime with plasticote engine primer, then at least 3 coats of what ever color engine enamel, then a couple coats of plasticoat clear engine enamel. all the motors i've done like this turn out really nice!! the clear keeps them looking wet.
Re: Painting your block. [Re: mopartoby] #203808
01/26/09 12:25 AM
01/26/09 12:25 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I should probably start a new thread instead of hi-jacking this one but since it concerns the painting of engines I'm going to ask...
How many people have powder coated their blocks, heads, intakes etc... instead of paint? I've painted my engine with single stage urethane numerous times and yes it looks really nice for the first year or two. That being said though after splashing some hot antifreeze on the paint it discolors and I've had a couple small spots peel where the a component wasn't obviously clean enough. I know paint can be touched up and I'm being anal here but it would seem like the powder coat option would give better longevity- or are there pitfalls?(other than cost)
Re: Painting your block. [Re: 72demon416] #203809
01/26/09 01:26 AM
01/26/09 01:26 AM
I had a aluminum intake and a set of cast aluminum rocker covers powder coated once back in the ealry 1990s, never again That darn powder coating is a great insulator, but it KEEPS the heat in instead of keeping the heat out. Heat rises so when it is hot in the motor and aluminum coducts heat very well and then the powder coating keeps the aluminum sealed up the parts get so hot you can't harddly touch them
Re: Painting your block. [Re: CrAzYMoPaRGuY] #203810
01/26/09 01:42 AM
01/26/09 01:42 AM
Eastern WA
P
ProStock1320 Online content
ProStock1320  Online Content
P
Eastern WA
LOL
OK, I'll ask an obvious question - how close is the Tremclad color to factory? I've seen some well intentioned companies that use the factory name but aren't even close. Is there a company that produces a dead-on product?
