Re: Coil springs
[Re: littlejohn44]
#2037544
03/24/16 12:13 AM
03/24/16 12:13 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Lowering the car 2 " to get a total of 5" of travel seems foolish, unless that is closer to where the front end stance should be. How low would that put the front end? Lowering the front end will increase the front end static weight. If your car doesn't hook up, it will spin even worse. Did you try unbolting the shocks to see if that is your front travel limiting factor?
[image][/image]
Re: Coil springs
[Re: littlejohn44]
#2038121
03/24/16 10:53 PM
03/24/16 10:53 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
A weaker longer spring that lowers the front is what you want. Lowering the whole truck sounds like a good idea
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Coil springs
[Re: littlejohn44]
#2038143
03/24/16 11:29 PM
03/24/16 11:29 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Was it a 4 cylinder truck? My D50 was and the springs on the front of it are too weak. I thought about cutting part of a coil off to lower the front a little and see what it will do.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Coil springs
[Re: littlejohn44]
#2038150
03/24/16 11:39 PM
03/24/16 11:39 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A spring of the same free length but with a lower rate will compress more when the same weight is applied to it, effectively lowering the front end. Whether it is too much or not enough depends on how much lighter it is. Too much and it will set dead on the stops. Not quite enough it can be shortened a bit to bring it down more. Plus the lighter spring will have more energy stored and will help get the front end to separate more easily.
Weight on the rear bumper will help it pitch rotate which is what your trying to do.
