Re: 727 Torqueflite Question
[Re: Killerinc]
#2036526
03/22/16 03:42 PM
03/22/16 03:42 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
On a lift the wheels won't move. Parking brake not releasing? With the driveshaft disconnected from the rear end are the wheels still immobile?
[Re: Killerinc]
#2036574
03/22/16 04:57 PM
03/22/16 04:57 PM
John_Kunkel
Rio Linda, CA
Wheels don't move at first then they do. Don't have the parking brake cable installed I'll repeat the question...do the wheels turn freely by hand with the motor off, trans in Neutral?
[Re: Killerinc]
#2036798
03/22/16 10:27 PM
03/22/16 10:27 PM
Posts: 566 WA
tman
WA
[Re: Killerinc]
#2036837
03/22/16 11:15 PM
03/22/16 11:15 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Are you saying the trans doesn't work cold and does warm? If so this classic symptoms of old hard rubber seals, it needs to be rebuilt.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Killerinc]
#2036989
03/23/16 08:59 AM
03/23/16 08:59 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I'd say it sounds more like a seals issue, but it would have to be both clutch drums to make both forward and reverse act up. Usually if it's converter drain-back it just takes a couple seconds in neutral to fill the converter, not 30-45.
It seems that now you are starting it, letting it run for a minute, and then when you put it in D or R there is a delay to engage - correct? Try starting it, putting it in N for that 1st minute, then trying D or N. If it moves right when you put it in gear, it's converter drain-back. If it takes time to engage - it's seals.
Some shift kits address converter drain-back. If it's seals, it's rebuild time. There are snake oils that may soften the seals, but are a temporary fix at best.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: barracuda7199]
#2037338
03/23/16 07:15 PM
03/23/16 07:15 PM
John_Kunkel
Rio Linda, CA
Sounds like converter drain back. Fire it up in neutral let it idle for a minute or so and then put it in gear. If it drives just fine it's the converter draining back. Very common. That is the next thing to try, always make the initial start of the day in Neutral not Park.
[Re: Killerinc]
#2037576
03/24/16 01:16 AM
03/24/16 01:16 AM
Posts: 71 NY
Killerinc
NY
Ok i tried it in neutral for 60 seconds and when i put it into reverse same thing. Do i have to actually start the car in neutral or after i start it in park put it in neutral?
[Re: Killerinc]
#2037631
03/24/16 04:05 AM
03/24/16 04:05 AM
Evil Spirit
Newport, Mi
Ok i tried it in neutral for 60 seconds and when i put it into reverse same thing. Do i have to actually start the car in neutral or after i start it in park put it in neutral? It doesn't really matter if you start in P or N - main issue is to get the trans in N reasonably soon to get the converter charge circuit flowing. But for arguments sake - start it in N. Since it really should not take more than a few seconds to fill converter - running it 60 seconds in N should have been more than plenty. So IMO if you already tried running it in N for 60 seconds and it didn't move when you put it into R within 1-2 seconds you have already ruled out a converter fill issue.
[Re: John_Kunkel]
#2037752
03/24/16 01:18 PM
03/24/16 01:18 PM
Posts: 596 Nashville, Tennessee
Tempest
Sounds like converter drain back. Fire it up in neutral let it idle for a minute or so and then put it in gear. If it drives just fine it's the converter draining back. Very common. That is the next thing to try, always make the initial start of the day in Neutral not Park. Ditto. My 50,000 mile RR does this exact thing. I always start the car and put into N. Rev motor to 1,500 or so for 20-30 seconds and then it's fine.
[Re: HemiRick]
#2037777
03/24/16 02:09 PM
03/24/16 02:09 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Are you saying the trans doesn't work cold and does warm? If so this classic symptoms of old hard rubber seals, it needs to be rebuilt. Are there specific seals that get hard and break or is it all of them?
[Re: WO23Coronet]
#2037792
03/24/16 02:32 PM
03/24/16 02:32 PM
Evil Spirit
Newport, Mi
Are you saying the trans doesn't work cold and does warm? If so this classic symptoms of old hard rubber seals, it needs to be rebuilt. Are there specific seals that get hard and break or is it all of them? It's usually the lip seals on the pistons in the clutch drums that cause this.
[Re: Evil Spirit]
#2037864
03/24/16 04:30 PM
03/24/16 04:30 PM
John_Kunkel
Rio Linda, CA
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Since everything else has been covered it's most likely hardened/shrunk piston lip seals. 20+ years of sitting doesn't help the life expectancy of rubber components. You could try some "miracle in a bottle" like Lucas or Trans-X, they will soften hardened seals.
