89 D350??
#2036472
03/22/16 02:35 PM
03/22/16 02:35 PM
Posts: 2,533 Alexandria, LA
Blucuda413
Alexandria, LA
Tell me the impt stuff about the 89 D350. Found one for sale but need to know what I need to look for before viewing. Standard cab, 360, auto, body nice, trans bad, heat & air doesn't work. Are they rare and sought after. I would use to tow enclosed auto trailer. Don't know how far I would go into restoration. I have a good SB 727. Any info would be appreciated!! Thanks, Max
Re: 89 D350??
[Re: Blucuda413]
#2036775
03/22/16 09:53 PM
03/22/16 09:53 PM
Posts: 5,966 Greenville, PA
redraptor
Greenville, PA
Standard cab, 360, auto, body nice, trans bad, heat & air doesn't work. Are they rare and sought after. ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) Sounds like a lot of work but, if that's what you want to do. Not remotely sought after unless it's a diesel for obvious reasons. If you like the body style and think it's the sh!t then go for it. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Re: 89 D350??
[Re: Blucuda413]
#2036902
03/23/16 12:51 AM
03/23/16 12:51 AM
Posts: 7,834 east side of Ohio
basketcase
east side of Ohio
typical D Series trucks, look for frame rust by the gas tank. all kinds of crap collects between the tank and frame. and the front=rear brake line is in there too, so it usually need replaced. rot on the roof above the windshield, inside and or out. check the cab mounts for rot as well.
1981 Dodge D150 360 auto
Re: 89 D350??
[Re: Blucuda413]
#2041720
03/30/16 04:59 AM
03/30/16 04:59 AM
Posts: 6,021 Salem
Grizzly
Moparts Proctologist
Salem
Max: It might, I think the 360 didn't get injection until '90 but it could have been as early as '89. At any rate you don't want a TBI Ram: they are crap, I had one. 99% sure it will have roller lifters. And, yes, actually to certain people who find the cost of owning a diesel to be outrageous (while the rest pull their head out of the sand and eventually realize it too) a 360 Ram HD is a decent score. But the 360 Magnum is much better...............much, much better. What else is important? First of all, the First Gen Ram is a noisy, rough, uncomfortable, ugly POS with mediocre reliability. Argue if you like: I've had 5 First Gens (one Cummins, 2 318's, 1 318 TBI, 1 Slant SIx), 4 Second Gens (two Cummins, a V10 and a 360 Mag) and 1 Third Gen Hemi. Overall, the Second Gen is the best of them all. The auto trans crapped out on this truck is no surprise. Chrysler couldn't build a 4 speed auto to save their life and it took Daimler to show them how it's done with the RFE series transmissions. I can't help you here other than to say buy low-mile autos from the wreckers for the same era truck and hope they hold up. If you put the the 727 in it will cost you at least 5 mpg. Pick your poison. The alternative would be to pull the 360 and put a V10/NV4500 in it. Skip that altogether and just get the 2nd Gen. Around here 2ndGen 2wd 2500's are going for $1300 to $2500.00. 4x4, add $600 I'm sorry to sound negative but there is a very good reason why Dodge only had 9% market share when these trucks were on the road. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) They are nothing to get exicited about and my only use for them is donors for my muscle cars and beaters that no one wants to be seen in. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Mo' Farts
Moderated by "tbagger".
Re: 89 D350??
[Re: Blucuda413]
#2042245
03/30/16 09:05 PM
03/30/16 09:05 PM
Posts: 5,971 ohio
ruderunner
ohio
And the counter point, I love em. 89 will have TBI, one ton is likely a 727 non lockup.
Rust is the big problem, roof rot, cab mounts and frame being the biggest problem. Floors are cheap and easy.
It will tow just fine, slowly. Mileage sucks but any one ton is going to be bad. TBI can be swapped to carb pretty easily. And yes the Magnum is much better but Mose costly and only available a couple years.
Angry white pureblood male
Re: 89 D350??
[Re: Blucuda413]
#2042812
03/31/16 05:10 PM
03/31/16 05:10 PM
Posts: 3,139 N.W. Florida
Fat_Mike
N.W. Florida
My son thinks I should get a short bed, I can't find one.
Thanks, Max
Better looking by far, but not a good choice for a tow vehicle.
Re: 89 D350??
[Re: Blucuda413]
#2043883
04/01/16 09:09 PM
04/01/16 09:09 PM
Posts: 5,971 ohio
ruderunner
ohio
Short beds are half ton or crew cab only.
